1. LuayS's Avatar
    Whenever I receive a snapchat or an sms my screen decides to wake. Is there anyway to disable this?
    04-15-2016 02:21 PM
  2. anon(238680)'s Avatar
    Well, that's the purpose of having notifications. You can either disable notification for those apps or turn do not disturb on.
    04-15-2016 03:12 PM
  3. LuayS's Avatar
    Well no I'd like to be notified if Im using my phone, and I'd like to be notified via LED or vibrate or sound or all if I choose to but I don't want my screen to turn on necessarily.
    04-15-2016 03:15 PM
  4. anon(238680)'s Avatar
    I have AOD enabled and just confirmed that, for an email notification at least, the phone did an audible and turned on the LED but did not light up the screen. Not sure if the same will occur with your apps but might be worth a try.
    04-15-2016 04:22 PM
  5. LuayS's Avatar
    It seems to only effect snapchat and sms. So weird.
    04-15-2016 04:46 PM
  6. Rick_Moli0212's Avatar
    You can disable Wake Screen for Snapchat in its settings.
    How to prevent Snapchat from waking your smartphone
    04-15-2016 05:17 PM
  7. meyerweb#CB's Avatar
    You can turn it off in Messeging, too. Settings/Notifications/ turn off Pop ups.
    04-16-2016 11:40 AM
  8. LuayS's Avatar
    I tried that still turned on. The snapchat setting worked tho!
    04-16-2016 02:08 PM
  9. meyerweb#CB's Avatar
    Odd. My screen doesn't come on with incoming messages.
    04-17-2016 06:33 PM
  1. Replies: 5
    Last Post: 05-08-2016, 03:02 PM
  2. Nexus 5 stuck in loading screen, how can I get it past this?
    By AC Question in forum Google Nexus 5
    Last Post: 04-18-2016, 02:37 AM
  3. What is the purpose of the usb port on the G5 cradle?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-16-2016, 03:31 AM
  4. Replies: 0
    Last Post: 04-15-2016, 01:03 PM
