1. Jguffey's Avatar
    Anyone having issues with slowdown and battery drain? Performance and battery life were amazing until this week. Under battery settings I'm seeing "android core apps" as the problem, eating up to 40 percent. I have already wiped the cache. I carry a work and personal phone. Testing 4 phones now all set up the exact same (note 4, note 5, s7, and s7 edge. The other phones are performing as expected. I really want to like the s7 edge, any ideas other than a factory reset?
    04-16-2016 11:52 PM
  2. dirtydantx's Avatar
    Go to Settings > System > Battery and click "More" in the top right corner, then click "Optimize battery usage". Tap "Apps not optimized" and change it to "All apps" and make sure they are turned on. This should help with battery life as well as the heating issue causing the processor to slow down.
    04-17-2016 12:25 AM
  3. Jguffey's Avatar
    OK I'll try that, thanks.
    04-17-2016 01:29 AM
  4. dirtydantx's Avatar
    Another thing that may help is turning off fast cable charging. Fast cable charging tends to heat up the phone if you are using it during fast charging. Best of luck!
    04-17-2016 01:30 AM
  1. Pink line of pixels down edge screen
    By ThePresentDayPachuco in forum Samsung Galaxy S7 edge
    Last Post: 02-18-2018, 06:40 AM
  2. New S7
    By Needkeys in forum Samsung Galaxy S7
    Last Post: 04-26-2016, 04:51 PM
  3. Galaxy S7 Restarting By Itself?
    By Shujinko in forum Ask a Question
    Last Post: 04-17-2016, 12:35 AM
  4. How Do I Update S7 On Root?
    Last Post: 04-17-2016, 12:33 AM
  5. New Samsung S7 -- Trying to add weather widget to home screen
    Last Post: 04-16-2016, 09:02 PM
