1. flintlock's Avatar
    Thought I'd play with the encryption for the card as I don't have much on it yet. It seems to go to the end then says there's an error. The files on the card are not visible afterward.
    Decryption works and ends with files being viewable again.
    It would kind of defeat my main purpose of wanting an external card--recovering data from bricked phone. But I wanted to play.
    04-17-2016 08:32 AM
  2. flintlock's Avatar
    Has no one tried the card encryption feature?
    05-04-2016 08:18 AM
  3. Tom_qwerty's Avatar
    Hey, this happens to me too. Really annoying. After coming up with the error message there's then an option to decrypt as well as encrypt. Hitting encrypt again just ends up with the same error. At least selecting decrypt seems to restore all the data (which isn't visible after encrypting)... But this means I can't get the encrypted SD card feature to work so I'm not sure if I want to be carrying around my phone with all my data so easily stealable if someone just picks up the phone!! Any advice or bug fixes from Samsung would be welcome....
    05-29-2016 06:31 AM
  4. flintlock's Avatar
    Thanks for the comeback. Looks like it just doesn't work and no one else has tried it
    06-10-2016 11:04 AM
  1. Replies: 4
    Last Post: 04-18-2016, 03:38 AM
  2. SD stop working / not detected in K012 (PadFone 7)
    By Doutormarinho in forum ASUS Fonepad 7
    Last Post: 04-17-2016, 11:05 PM
  3. How do I install a new micro sd card on galaxy note 10.1
    Last Post: 04-17-2016, 06:15 AM
  4. Sd card unavailable
    Last Post: 04-17-2016, 01:56 AM
  5. Replies: 0
    Last Post: 04-17-2016, 12:29 AM
