Twitter Notification Sound?
Kasper610
72
My twitter Notification sounds keeps going back to default? No matter what I set it to, it never sticks. Is this happening to anyone else. I've looked at the permission settings in the phone and I cant seem to figure out why the twitter sound wont stick. Any help please......
Kasper610
72
Is there a "Fix" for this that you know of.... Its so annoying.... I set the sound, exit out, go back to check and it's on the default sound again!
insane42
118
4
Only way I've done it is to install a 3rd party handler like one of the File Managers. Pick your sound with that, and it seems to stick. I'm annoyed by this as well, and Twitter @support ignores me.
tcdude
636
Yes it's happened to me too I just stop trying to change it after a while, anyone know if this a device issue or a marshmallow issue?
veselinmarkovic
Anyone know if there's a way to set the notification sound to Silent using a 3rd party handler, as you normally do in Android's default Sound Picker (if only it worked)?
Thanks!
