08-14-2018 06:48 PM
168 ... 23456 ...
tools
  1. RichBrown68's Avatar
    I had my S6 Edge Plus for 7 months, the night clock feature on the edge was always on, no sign of burn in anywhere
    04-26-2016 10:12 AM
  2. tnt4's Avatar
    The other potential problem with OLED is the inconsistencies with the panels. It seems to have become more of a problem after they started pumping out screens with quad HD resolution. Some come with slight pink hue fades, for example - this is actually a pretty widespread "issue", but it's not a horrible one by any means. It just bothers me that a flaghsip, $600+ device would have any inconsistency at all.
    I had a Droid Turbo with it a couple of years ago and now I can't unsee it on any OLED panel that has it, even slightly. All of the top OLED displays the past couple of years have had this issue - S6, S7, Turbo/2, Nexus 6/6P
    Here is a good example, though the fade varies in intensity and location from device to device:
    https://onedrive.live.com/redir?resi...nt=photo%2cjpg
    04-26-2016 10:14 AM
  3. Connor Thompson's Avatar
    I have had a Nexus 6 for a round 9/10 months now and the Navigation Bar at the bottom has started to burn into the screen. It's fairly faint but on certain colours I can always see the bar and the navigation icons, and I haven't even had it that long. This is probably due to the fact these are near enough constantly shown on screen, so may not be so bad on phones which don't have constant elements.
    gg22 likes this.
    04-26-2016 10:34 AM
  4. wmurch3's Avatar
    Got a Note 4 on ebay a few weeks ago that has horrible screen burn in. I compared it to a coworkers who also has a note 4 and it's like night and day. 3/4 of my screen had a yellow/orange tint and at the top it was white and you could make out the status bar icons against a blue/white screen.
    Yes this is a real issue.
    1812dave likes this.
    04-26-2016 11:42 AM
  5. jer85008's Avatar
    Mine was fine for the first year as well. Purchased in Nov 2014, and was a daily driver since. Burn in started a few months ago and got bad fairly quick. My front glass was severely cracked, then the battery started flaking out so I retired it a few weeks ago.
    04-26-2016 11:45 AM
  6. 1812dave's Avatar
    My wife's Note 2 is slightly more bluish than mine and for me that's not too cool, because I don't like the warmish-yellowly-green tinge that my Note 2 has when displaying what SHOULD BE a white color, although neither display, like every Note 2 I've seen has the same dingy whites. Our two S7's having a much improved color temperature and are for all intents and purposes, indistinguishable from each other.
    04-26-2016 11:47 AM
  7. dsstrainer's Avatar
    And what are you displaying on your screen for extended periods of time?
    04-26-2016 12:09 PM
  8. T Redd's Avatar
    This happening to my galaxy note 4. The screen is turning yellowish. The notification bar burned in.
    wmurch3 likes this.
    04-26-2016 03:31 PM
  9. mptp's Avatar
    My old SGS3 has terrible burn in all over the screen. No longer my primary device but I use it daily for navigation and such. I first saw the affects of burn in after about 8 months of usage as my primary.
    Not that it applies to AMOLED, but my Moto X Pure, after 7 months of heavy usage, shows no signs of burn on its LCD.
    04-26-2016 05:48 PM
  10. robh2's Avatar
    Wife and I both have Galaxy S5's and we both had bad burn in. Hers was of the keyboard and mine was mostly gmail layout burn in. If I remember correctly we had it on both of our S3's also, just not as bad.
    04-26-2016 08:54 PM
  11. barry99705's Avatar
    But these situations always only happen to a
    "a friend," rarely to the person posting.
    On the plus side, looks like I'm averaging the high 50's for speed....
    LanceAllan likes this.
    04-26-2016 09:46 PM
  12. ThrottleJohnny's Avatar
    I'm sure it can happen. I'm I worried about it? No
    04-26-2016 10:58 PM
  13. everywill's Avatar
    Bought a Dell venue 7840 from Bestbuy open box sale. The screen etched with the initial setup frame, the one shown language options. Those texts are even clearly readable under white, grey, green and blue background.
    Currently my daily driver is a s7 edge. Considering I use waze and TomTom go quite often, I'm worrying about the burn in of those static elements such as menu, zoom in/out buttons etc. Kind of regret now. Should wait for the G5. Sure, the contrast of AMOLED is amazing and definitely the best choice for media consuming. But whether the constant concern could justify the benefits.... I don't know.
    04-27-2016 08:39 AM
  14. 1812dave's Avatar
    One reason especially that concerns me about burn-in is the fact I can't afford to shell out for a new phone every year, coupled with the fact I'm anal that my things being in perfect shape. I don't do defective, scratched, etc well.
    JavaNoire likes this.
    04-27-2016 09:01 AM
  15. icecoolfsu's Avatar
    This is a problem? There is a Note 2 & Note 4 in my family and neither have burn-in. Yes, your screen will burn in when you have one screen up 18 hours a day for a year. That's not a real work problem. Who just stares at one screen all day without interacting with it? #FirstWorldProblems
    04-27-2016 10:24 AM
  16. Uselessbass's Avatar
    I have had samsungs since galaxy s2 days, never have had burn in even on those older devices I would not worry about it.
    04-27-2016 10:32 AM
  17. everywill's Avatar
    One example would be when you use your phone as a sat nav or traffic report receiver for daily commuting. There are always some static elements on the screen no matter how the map/data move. Obviously, direct sunshine and associated heat could accelerate the ageing of those pixels also.
    In general, this could happened if you have one regular used app. No matter how you interact with the contents, just like what someone said above, the frame of the app will eventually "etch" in the screen. The process could be faster if the UI uses a lot of shades of blue.
    04-27-2016 12:13 PM
  18. mary beth hale's Avatar
    All that means is that you didn't have static images on your phone from a frequently-used application. It doesn't mean the technology isn't prone to burn-in. If you had 25 phones without burn-in, it doesn't mean the issue doesn't exist. It's a matter of use case.
    I know. That's why I said moot point for me. Wasn't saying it doesnt happen to others.
    04-27-2016 12:29 PM
  19. everywill's Avatar
    Burn in is a inherent problem of AMOLED. For some it could become quite severe within short period of time; and, for others, they won't notice along the whole lifespan of the device. Please don't assume everyone should use their device as the way you did. Even if someone choose to display static image, such as their kid's photo, constantly, that's their choice. If such style of using will cause hardware problem, then there is a problem, there's no way to say it's not exist or "you wouldn't notice", "you shouldn't care" etc. You won't know others' standard of good and bad and you have no right to judge people's way of using right or wrong.
    As an end user, there's no need to help manufactures to window-dressing inherent defects of certain technology. Instead, criticism has long been a strong power to push techs forward. Even if you are not suffering the burn in, you should at least criticize manufactures not educate perspective customers to be aware of this potential problem.
    04-27-2016 12:38 PM
  20. tnt4's Avatar
    Great point - and honestly I don't get the benefit of AMOLED anyway. It doesn't provide better battery life, has inherent issues as mentioned in this thread (burn in plus screen inconsistencies even in flagships), and makes things look less realistic. Yes, if done right, they can sometimes look "better", but it's still less realistic. My eyes still feel a sense of relief when going from the best AMOLED panel to an IPS panel. And no matter what I do, my S7 still looks more "cartoonish" than my Nexus 5X or iPhone 6S.
    04-27-2016 01:24 PM
  21. RichBrown68's Avatar
    I think this point works the other way too. Apple and LG and all the companies that use LCD displays aren't in need of people going around bashing the competition for their sakes.
    04-27-2016 01:43 PM
  22. tlacour's Avatar
    We have a Note 4 and a Turbo 2. Both have burn in at the notification bar at the top. The Note also has burn in at the dock icons at the bottom. The Turbo has it where the vurtual keys bar at the bottom. These are almost always up.
    Take your Notes, download a pure white pic, and look at it in full screen. I would bet, if you're honest, you can see at least some ghosting of the notification bar and dock icons.
    T
    04-27-2016 03:19 PM
  23. RichBrown68's Avatar
    I posted over in the Galaxy S4 forum and asked if anybody had had issues with burnin, to please post and let us know. The only people who posted said they had not noticed any problem. Nobody posted saying they did have a problem. Mind you, this is a phone that is 3 years old, but it's a forum where nobody has a point to prove.
    04-27-2016 03:29 PM
  24. 1812dave's Avatar
    The S4 forum is old and therefore it won't have the traffic that an S7 Forum has so asking about any problem on the S4 forum isn't likely to result in many responses.
    04-27-2016 03:39 PM
  25. RichBrown68's Avatar
    Lol whatever dude.
    04-27-2016 04:18 PM
168 ... 23456 ...
  1. 3G & Non-3G Sport Band the same?
    By thomasmarcgodskid in forum Samsung Gear S2
    Last Post: 04-27-2016, 03:54 PM
  2. Got a little change in my pocket...
    By louisstone in forum Android Apps
    Last Post: 04-23-2016, 09:31 PM
  3. Samsung Good Lock is awesome.
    By yaddam205 in forum Samsung Galaxy S6
    Last Post: 04-21-2016, 06:56 PM
  4. Replies: 1
    Last Post: 04-20-2016, 10:39 AM
  5. Replies: 0
    Last Post: 04-19-2016, 10:39 PM
