DroidCoffee
My old Lumia 520 had a lot burn ins in my screen, It didn't even take that long time from displayed content to burn in.
Just tried that on my 1.5 year old Note 4, even turned screen brightness to max and I can honestly say I see absolutely zero ghosting or any type of artifact indicating screen burn in of any kind. Then again, even though it's been used heavily it's never had any kind of static content on the screen for any long duration and screen brightness has always been left on auto (only maxed out from time to time when in full sunlight), as well as its most used app, the stock Samsung browser, has always been set to hide the notification bar.
Quantum dots are actually in use now, but only as a backlight. LG's G4, V10 and G5 use a similar display tech.I thought I remembered that Amazon's HDX tablets, that is their high-end ones, used something called Quantum dots technology. Or am I miss remembering?
Trust me, it's not exagerated. I had a Galaxy s6 Edge Plus which was only 5 months old. I had used the TomTom speed camera app and it had caused screen burn. I had got used to it even although it was quite unsightly but when I sold the phone via Mazuma the original price offered was £260. Then when I sent them the phone they reduced the offer to £110 because of the screen burn. This was all down to a single app which I had used for 2 or 3 hours per day for 5 months. Be warned!
I was about to reply there aren't any on screen navigation keys on the S7 (this is an S7 forum). Anyway, isn't there an option to hide the keys on pixel? You may want to ask the pixel forum for that.Any thoughts on leaving a phone on"screen saver" mode overnight? Brightness all the way down and night light on. It moves the clock around but the on-screen navigation keys stay lit which I'm worried about. It's the pixel XL for what it's worth.
Dang I didn't know about this issue. Just got an S7Edge as I went from a Note 7. Oh well I'm not planning on having my S7 that long as I'll be upgrading to the Note 8 in September.
Apparently, Samsung is working on a new display tech called QLED, or Quantum-dot Light-Emitting Diodes. They're planning to begin mass-production in a few years on their TVs.
Widely believed to be the next big new display tech after OLED, QLED is almost like OLED, in the sense that it is self-illuminated and doesn't require a backlight. However, because it isn't organic, it's much more durable than OLED and it can apparently last longer.
So, it's basically the superb contrast and punchy colors of OLED mixed in with the durability and lifespan of LCD. Love it.
I have had my S4 for 4 years. It has thousands and thousands of hours on it and was used every single day since I bought it until I got the S7 Edge about a month ago. It has zero burn in on any of the colour screens. I am not sure what you guys are doing to cause screen burn in but, it's likely a user error issue. Leaving stationary objects on the screen for hours on end(like using it as a GPS with the screen on for hours) will cause burn in on any screen on any device and is warned against by pretty much all manufacturers of LCD/LED screens so don't do it. If you do that is abuse. Under normal use(not abuse) it is not a problem for most users.yeah? try this apps and tell me if dont see any shadow in status bar in blue color test if you have a device used for more than a year. I had S2, S3, S5, Note, Note2, Note3, all had burn mark after a year of use.
Dead Pixel Test
https://forums.androidcentral.com/e....ossibussoftware.deadpixeltest&token=eTaqrCcm
Same here. My Note 4 doesn't have burn in and neither does my old S4.You most likely won't even have the problem. My oldest phones are a Note 4 and a Note Edge. I haven't noticed any burn in on either of them if it is there at all.
I had a Note 4 since launch day, I have now borrowed it to a friend, STILL no burn-in. My S4 I've also had since launch, also, no burn-in. Both phones are well over 2years old now. My S4 must be almost 4 years old now? Got it in April 2013.yeah? try this apps and tell me if dont see any shadow in status bar in blue color test if you have a device used for more than a year. I had S2, S3, S5, Note, Note2, Note3, all had burn mark after a year of use.
Dead Pixel Test
https://forums.androidcentral.com/e....ossibussoftware.deadpixeltest&token=0TxDYE83
