sparksd
Same here. My Note 4 doesn't have burn in and neither does my old S4.
I doubt my S7 EDGE will get it.
I had the Note 4 for 2+ years, always used brightness at full and had no burn-in.
You should be fine.I bought the S7 Edge a month ago and had never heard about this issue. Now I am a bit worried. I usually keep the brightness on automatic mode and around the middle of the bar (never too bright, nor too low. I have also disabled the always-on display). I usually use the phone a lot during the day, but never more then 10 minutes straight without leaving it to rest a bit before my next usage.
Do you think my phone will be fine in the long term?
Seems to vary. I've had mine on auto since day one (release day), typically keeps at around 40-50% where I use it most. I have burn in where the blue part of the Facebook app is, which is typical of AMOLED displays. Wish Samsung would fix this, not even had the phone a year and the screen is burned already.
You have never heard of amoled issue before? Or you havent heard about specifically on s7 edge?I bought the S7 Edge a month ago and had never heard about this issue. Now I am a bit worried. I usually keep the brightness on automatic mode and around the middle of the bar (never too bright, nor too low. I have also disabled the always-on display). I usually use the phone a lot during the day, but never more then 10 minutes straight without leaving it to rest a bit before my next usage.
Burn in can happen on all displays, not just AMOLED. And, leaving static images on screen for extended periods is considered abuse by most panel manufacturers. Just don't leave static images on for hours on end and you won't have an issue.Burn in is real and happens when a statci image is displayed for prolonged time. Go to amy demo Samsung phone and youll see pretty severe burn in. Bur in was true back in galaxy days and is true today.
While it is true that burn in happens on all displays, however, amoled screens, no just samsungs iteration, is vastly more susceptible to burn ins than LCD type displays. That is a cold fact that cannot be argued with no matter how much we love our amoled screens. I dont mean to old head members on this forum but i have been with Samsungs and other type amoled screens since day one going all the way back to samsung omnia with symbian s60 days.Burn in can happen on all displays, not just AMOLED. And, leaving static images on screen for extended periods is considered abuse by most panel manufacturers. Just don't leave static images on for hours on end and you won't have an issue.
Burn in is a user error issue, not a manufacturing issue.
I'm wondering the same thing.How in the world are you burning in screens like this? I know it's possible but really? I've got 4, 5 year old AMOLEDs with no burn ins.
