1. dman76's Avatar
    I was messing around with the My Places on the Edge Panel to set the ringer when I am home, Bluetooth, etc. What I would like to be able to do is set it to vibrate when I leave home. Is there a way to do that? I can make it do things at certain locations but can you make it do things when you are NOT at a certain place?
    04-20-2016 11:17 AM
  2. SpookDroid's Avatar
    Not sure with that, but you should be able to do it with automation 3rd party apps like Tasker or IFTTT. Not as simple as My Places, but way more options and actions (not only places, you can do automatic tasks with a lot of things...text messages, widgets, e-mails, etc.)
    04-20-2016 12:15 PM
  3. Jeremy MacMull's Avatar
    Yeah use tasker and literally anything you can do with your phone is possible.
    The my places is a bit limited but does enough for most.
    04-20-2016 01:56 PM
  1. Am I the only one that presses the edge unintentionally constantly?
    By Zendroid1 in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2016, 03:01 PM
  2. Is it just me? Or is it just my phone?
    By loveleighn in forum Android 4.4 KitKat
    Last Post: 04-26-2016, 12:50 PM
  3. Replies: 2
    Last Post: 04-24-2016, 12:35 PM
  4. Replies: 1
    Last Post: 04-21-2016, 01:52 PM
  5. Replies: 1
    Last Post: 04-20-2016, 01:15 PM
