04-25-2016 06:32 PM
79 1234
tools
  1. Scutley's Avatar
    Nope. Even after the first time, fingerprint doesn't unlock lockscreen for ne. Takes me to keypad for pin. Fingerprint still works with Samsung pay and signing into websites via stock Internet app. Just won't unlock lockscreen. Am I the only one?
    Try going into your settings and see if the option is off or on.
    04-21-2016 12:32 PM
  2. abaishya's Avatar
    You probably have Nova activated as a device administrator for unlocking your screen. I disabled that, which removed the double tap to lock screen. Now I just press the power button to lock. Fingerprint unlock was more important than double tap to lock for me.
    Thiscrapsucks35 and LSG67 like this.
    04-21-2016 12:55 PM
  3. atlsport's Avatar
    Yep it seems to be the Nova double-tap. Disable that and my fingerprint unlocks the screen every time. Double-tap to lock it and only a pin will get you back in. Explains why every now and then my fingerprint was working... when the phone locked itself due to timeout setting. But when I used double-tap to lock, it was a no-go. I'll see if I can report it to Nova. Thanks for the detective work, guys. One of the many reasons I love these forums.
    04-21-2016 01:11 PM
  4. Thiscrapsucks35's Avatar
    Yep. That was it for me.
    04-21-2016 01:21 PM
  5. Thiscrapsucks35's Avatar
    If you have Nova set as an administrator on your phone, you'll probably be experiencing this issue.
    04-21-2016 01:22 PM
  6. atlsport's Avatar
    For me it's just using double-tap to lock. I still have Nova as a device administrator but disabled the double-tap thing in gestures. Now my fingerprint unlocks the lockscreen every time. Yay.
    04-21-2016 01:30 PM
  7. Almeuit's Avatar
    So I used the Samsung+ app to do a live chat with an agent. Since I did a factory reset to try to resolve the issue, they recommended that I take the phone to Best Buy and have the Samsung folks there do "something" (I forget what she called it). I'm hoping that works. Otherwise what? Replacement phone???
    Update: I'm thinking the problem might be Nova. I don't know what Nova has to do with the lock screen, but when I am having the problem, Nova is the default launcher... and the problem is happening at a high clip... maybe 95% of the time. When I switch over to Touchwiz, the fingerprint unlocks the phone 100% of the time.
    It could either be that or you may just need to do a Factory Reset. I would do a FDR first before going through any replacements.
    04-21-2016 01:35 PM
  8. Dan TheMan86's Avatar
    After the update, battery life seems to be worse. Although it's been getting steadily worse and worse since I bought the phone two weeks ago. An hour of screen on time seems worth about 20-25% of battery life
    EDIT: Just realized this was posted in the Edge section. I have just the regular S7
    04-21-2016 01:47 PM
  9. tsells's Avatar
    Yup. That was the cause of my problems too. THANKS!!!
    04-21-2016 02:51 PM
  10. Thiscrapsucks35's Avatar
    I DID a FDR (see 2nd sentence you quoted).
    04-21-2016 03:09 PM
  11. Almeuit's Avatar
    Ah yep I read right over that. Hm weird....
    04-21-2016 03:42 PM
  12. llckll's Avatar
    Does anyone have a full list of what is included?
    I can tell you right now that I have absolutely zero lag when typing. Prior to this update the keyboard was lagging very bad.
    04-21-2016 06:01 PM
  13. digitalbreak's Avatar
    It looks like ATT has released two updates so far, the one with the April security patch being the latest.
    The one I received first was the previous update. Apologies for the confusion.
    04-21-2016 06:16 PM
  14. John Segura1's Avatar
    I received the update yesterday. I noticed right away that my wifi issues were fixed and the screen and overall response have improved.
    04-22-2016 04:14 AM
  15. Ryan G1's Avatar
    Updated today. Lost the ability to unlock the lockscreen with fingerprints. Have to key in the pin. Anyone else?
    On the s7 edge every time you restart your phone it will prompt for your 4 digit password. After that you should be good unless you thumb print security setup is wrong.
    04-22-2016 12:09 PM
  16. gtg465x's Avatar
    Meow
    04-22-2016 01:16 PM
  17. Dan TheMan86's Avatar
    After this update I've noticed more lag on the phone and considerably worse battery life. Back to that tethered life...
    04-22-2016 01:25 PM
  18. StayFly's Avatar
    My battery life is terrible now, I had problems with my phone resetting by itself. It would mostly happened when I was downloading videos on youtube, it would just restart. I called att they said there's a new update out try that to see if it fixes your issue. I had 1 reset so far but the battery life is terrible now.
    Dan TheMan86 likes this.
    04-22-2016 04:39 PM
  19. ABOSWORTH007's Avatar
    I got the update yesterday. Definitely seems improved. I haven't had any random spit screen activation since the update.
    04-22-2016 08:36 PM
  20. erasat's Avatar
    All of you with issues and worse battery life, have you done a wipe cache in Recovery menu? It's always recommend to do it after an update.
    04-22-2016 11:40 PM
  21. jneusch's Avatar
    Quick reminder please on how to do it for those of us that have forgotten?
    04-23-2016 07:48 AM
  22. ironass's Avatar
    Here you go...
    04-23-2016 07:55 AM
  23. mayconvert's Avatar
    Feels faster...
    No issues for me. installed.
    04-23-2016 11:13 AM
  24. Google10's Avatar
    Decided to leave it off the charger overnight to check for a difference. It lost a lot more battery than usual almost like doze wasn't working at all...
    04-23-2016 11:20 AM
  25. dfb8085's Avatar
    $700 phone ought to be smooth from the get go. If its not I'm getting a refund
    04-24-2016 07:26 PM
79 1234
  1. GS5 Boot loops after update
    By Wolfsv in forum Samsung Galaxy S5
    Last Post: 05-01-2016, 10:56 PM
  2. Am I the only one that presses the edge unintentionally constantly?
    By Zendroid1 in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2016, 04:01 PM
  3. Replies: 2
    Last Post: 04-24-2016, 01:35 PM
  4. Settings with My Places on Edge Panel
    By dman76 in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2016, 02:56 PM
  5. Galaxy S7 Email Issues
    Last Post: 04-20-2016, 10:50 AM
