04-25-2016 06:32 PM
79 ... 234
tools
  1. Dan TheMan86's Avatar
    All of you with issues and worse battery life, have you done a wipe cache in Recovery menu? It's always recommend to do it after an update.
    What all does this erase? Is it safe? Why wouldn't this be built in to Android to happen automatically after an update if its recommended? Suspicious of BS here...
    Also wanted to note after a few days, my battery life is still not as good as it was 3 weeks ago when I bought the phone.
    04-25-2016 08:44 AM
  2. erasat's Avatar
    Ask with a better attitude next time and I'm sure more people will answer and help you.
    No BS, it's safe to do it, not a single personal file or app are deleted just OS junk. Why it doesn't do it automatically? Well, ask Google, and even if they does it now (no way on knowing) no harm on doing it again, as most of the time your phone begin to behave strange or not normal, a simple Wipe Cache Partition can do magic.
    It's fine if you don't do it, that's up to you, but a thing like this that can take no more than 5 minutes in total to complete, can save you tons of time troubleshooting and also a lot of frustration.
    04-25-2016 10:26 AM
  3. Dan TheMan86's Avatar
    With the massive amount of BS and people on the internet that spew out "information" that they know nothing about, it's hard to maintain a better attitude. Trust me.
    I guess I'll do some research into this.
    04-25-2016 02:13 PM
  4. tsells's Avatar
    Do the wipe cache for sure. It is harmless and can definitely help.
    But also consider a "rogue app" as the possible culprit for your battery problems. Or did you install any new apps recently?
    My S7 Edge has great battery life, and it continued after the recent ATT update.
    04-25-2016 06:32 PM
79 ... 234
  1. GS5 Boot loops after update
    By Wolfsv in forum Samsung Galaxy S5
    Last Post: 05-01-2016, 10:56 PM
  2. Am I the only one that presses the edge unintentionally constantly?
    By Zendroid1 in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2016, 04:01 PM
  3. Replies: 2
    Last Post: 04-24-2016, 01:35 PM
  4. Settings with My Places on Edge Panel
    By dman76 in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2016, 02:56 PM
  5. Galaxy S7 Email Issues
    Last Post: 04-20-2016, 10:50 AM
