I installed DU Battery Saver, which has some other tools with it. I also installed DU Speed Booster.
Are apps like this necessary, or even useful/safe???
Thanks.
Thanks.
Marshmallow has built in battery optimization for apps. Just saying..
So, the novice that I am can presume that optimization tools are really not necessary. Correct?
Just uninstall any of the "optimizer tools" you may have and even the default installed Lookout, the Anti-Virus are not needed unless you are the kind of just download piracy or APKs outside of Play Store, and the "optimizers" are not needed at all on Android, plus Marshmallow has the Battery optimizer called Doze baked into the OS.
Thanks, erasat. I will take your advice, and teeitupmo's, and uninstall optimizers and lookout. I guess that means that I should uninstall the Bitdefender AV that I installed, too. ???
