1. Pastorhss's Avatar
    I installed DU Battery Saver, which has some other tools with it. I also installed DU Speed Booster.
    Are apps like this necessary, or even useful/safe???
    Thanks.
    04-21-2016 10:28 AM
  2. teeitupmo#WN's Avatar
    Marshmallow has built in battery optimization for apps. Just saying..
    Pastorhss likes this.
    04-21-2016 11:31 AM
  3. Pastorhss's Avatar
    So, the novice that I am can presume that optimization tools are really not necessary. Correct?
    04-21-2016 12:31 PM
  4. erasat's Avatar
    Just uninstall any of the "optimizer tools" you may have and even the default installed Lookout, the Anti-Virus are not needed unless you are the kind of just download piracy or APKs outside of Play Store, and the "optimizers" are not needed at all on Android, plus Marshmallow has the Battery optimizer called Doze baked into the OS.
    04-21-2016 02:27 PM
  5. Pastorhss's Avatar
    Thanks, erasat. I will take your advice, and teeitupmo's, and uninstall optimizers and lookout. I guess that means that I should uninstall the Bitdefender AV that I installed, too. ???
    04-21-2016 03:39 PM
  6. erasat's Avatar
    Again, I never use or recommend using Antivirus apps, BUT, if you think you are going to be downloading files from everywhere and installing external APKs then you better leave something in there to protect your phone. But definitely even in worst case scenario you don't need more than one app for that.
    04-21-2016 03:55 PM
  7. Pastorhss's Avatar
    Thanks, again.
    04-21-2016 04:09 PM
  8. Rukbat's Avatar
    Antivirus apps (one of them) should be instlled. Also Malwarebytes Anti-Malware. "Battery optimizers" and "memory managers" (apps that kill "unused" apps in RAM) should never be installed, and I'd be suspicious of any apps written by the same companies. Optimizing the battery and memory usage are Windows things - writing apps to do that on Android just shows that the developer doesn't understand Android.
    04-21-2016 04:31 PM
  1. Replies: 3
    Last Post: 05-04-2016, 06:56 AM
  2. Calendar using 31% of my battery?
    By kramer5150 in forum General Help and How To
    Last Post: 04-22-2016, 01:27 PM
  3. LG G3 Stuck on on "Optimizing app" how to reset?
    By AC Question in forum LG G3
    Last Post: 04-21-2016, 08:41 AM
  4. samsung s6 andorid 6 battery drain
    Last Post: 04-21-2016, 04:02 AM
  5. Replies: 0
    Last Post: 04-20-2016, 06:12 PM
