1. wisewhisk's Avatar
    Hi everyone,
    I have to send back my S7 Edge due to a pixel issue. I want to wipe the phone before sending it. On previous phones, I encrypted the phone before doing a factor reset. I can't find that option on the S7. Is it because Android Marshmallow defaults to encryption? If anyone has advice, that would be great.
    Thanks!
    04-21-2016 09:54 AM
  2. teeitupmo#WN's Avatar
    I wouldn't worry about it . just do the factory reset. The factory reset wipes out encryption or decrypts then wipes anyways.
    04-21-2016 10:30 AM
  3. Rukbat's Avatar
    Or you could flash the stock ROM (which is trivial with a Samsung - see [Samsung] How to flash Stock ROM via ODIN). That would probably give even the NSA heartburn.
    04-22-2016 11:54 AM
  1. Ring multiple devices
    By N4Newbie in forum Google Project Fi
    Last Post: 05-08-2016, 08:37 PM
  2. Replies: 1
    Last Post: 04-21-2016, 01:30 PM
  3. Which Blood Pressure Monitor Device is Best ?
    Last Post: 04-21-2016, 04:01 AM
  4. Will data on an unlocked S7 work as well as on a T-Mobile device?
    By markwest1 in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2016, 11:22 PM
  5. Replies: 0
    Last Post: 04-20-2016, 10:38 PM
