1. RockyMin's Avatar
    I've been using the magnifier on the S7 edge but when I touch the save button in it to save a magnified image, I can't seem to find where it is saved. I've checked through all the folders associated with the camera and picture files but I can't find any saved captures from the magnifier.
    Does anyone know where this is located? Thanks.
    04-21-2016 01:24 PM
  2. Deakon67's Avatar
    It isn't found in your gallery? Mine are easy to find there.
    Edit: I guess you are looking for a folder now that i read your post again.. Not sure where it physically saves them to.
    04-21-2016 03:45 PM
  3. Alanhd's Avatar
    If they show in the Gallery you can select More / Details it should show the storage location.
    04-21-2016 04:32 PM
  4. RockyMin's Avatar
    They don't show in the gallery or anywhere else screenshots and photos are supposed to be. I'm wondering if you need an SD card to save magnifier catches.
    04-22-2016 08:18 AM
  5. Lana 524's Avatar
    I have an SD card and they don't seem to be saved anywhere for me either. Frustrating!
    05-25-2016 11:31 AM
  1. Replies: 1
    Last Post: 05-20-2016, 11:52 AM
  2. Can I get some help with a problem that I am having with music apps?
    By MusicMagsandWax in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2016, 05:30 PM
  3. Big google connection problem will Reinstalling android help??
    By Nirgranth in forum Android 4.4 KitKat
    Last Post: 04-21-2016, 01:08 PM
  4. OS update need help, old phone
    By kai1432 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 04-21-2016, 05:57 AM
  5. Replies: 1
    Last Post: 04-21-2016, 04:30 AM
