1. Thomas Gruver's Avatar
    I keep getting the notification that says "unfortunately calendar has stopped. I've tried clearing both the data and the cache and this sometimes works but the notification always seems to come back sometime later. Any idea how I can fix this?
    04-21-2016 06:14 PM
  2. Thomas Gruver's Avatar
    Nobody?
    04-22-2016 08:45 AM
  3. marlin29311's Avatar
    Try clearing your app cache through the reboot process.
    If that fails, only other option would be to do a full reset, or disable the calendar app and use a separate one from the play store, such as "Google Calendar."
    04-22-2016 09:38 AM
  4. Thomas Gruver's Avatar
    Reboot definitely fixes it... but only temporarily. Can't believe that one of the likely top apps a user would use on this phone is so buggy. It's also starting to happen more frequently with the Samsung mail app as well.
    Am I really the only one seeing this?
    04-26-2016 09:34 AM
  5. marlin29311's Avatar
    Have to cleared the cache partition as I noted above? A lot of times this can help with buggy apps.
    05-03-2016 08:18 AM
  6. TenchiZ's Avatar
    I am having the exact same problem. Clearing the cache does not help. Uninstalling and reinstalling the Google Calendar does not help. Rebooting fixes the problem for amount of time and then it comes back. The calendar crashes up to 10 or 12 times a day. Using a stock S7 Edge on Sprint.
    07-16-2016 05:46 PM
  1. Replies: 2
    Last Post: 05-28-2016, 03:47 PM
  2. 'Print' makes the print screen crash?
    By Deakon67 in forum Samsung Galaxy S7 edge
    Last Post: 04-21-2016, 11:30 PM
  3. what else can I keep in the sd card besides photos?
    By trexs7e in forum Samsung Galaxy S7 edge
    Last Post: 04-21-2016, 10:13 PM
  4. Replies: 0
    Last Post: 04-21-2016, 05:49 PM
  5. Replies: 1
    Last Post: 04-21-2016, 12:11 PM
