1. person1001's Avatar
    well I don't know what to say, I have the phone for 5 days now, yesterday I did a funny thing (not funny for me actually ) I plugged the charger to the phone to charge it and the phone didn't charge, I was shocked and desperately started to plug and unplug it several times but no hope the phone wouldn't charge, after a while I realised that I forgot to plug the charger to the wall , anyway my question is: is the 'tongue"inside the charging port in the phone durable enough? I mean I did about 5 tries, but I used no pressure just plug and unplug repeatedly, is it like charging the phone every day for 5 days? or plugging and unplugging repeatedly is a different story?
    well I checked the port it's good nothing bent or damaged I just noticed 2 carved marks on the rubber at the down side I believe the 2 pins on the charger's port are responsible for this, and I also noticed that the port goes inside the phone smoothly now, it's a little bit loose, don't know if this supposed to happen by time anyway, so the phone charges and everything, just want to know whether should I expect port failure in the next few days? I also want to know if what I did can affect battery life
    04-21-2016 10:39 PM
  2. PJRed2008's Avatar
    I came from an SIII that I charged every day for over 3 and a half years and it is still going strong. That being said the port is fragile and you probably did it no good. Get a wireless charger and you won't have to worry about it.
    04-21-2016 11:48 PM
  3. person1001's Avatar
    thank you and sorry for my late reply, I will get one ASAP but can what I did affect battery life?
    04-22-2016 09:24 PM
  4. Jaycemiskel's Avatar
    It won't affect battery life. I don't think you have to worry too much
    04-22-2016 10:12 PM
  5. meyerweb#CB's Avatar
    I don't think you really need to worry about the charging port, either. Unless you're really ham-fisted, they'll last for years and years.
    04-22-2016 10:38 PM
  6. person1001's Avatar
    Thank u so much guys
    04-24-2016 07:36 AM
  1. Replies: 17
    Last Post: 04-25-2016, 12:04 PM
  2. Charging message
    By pduffer in forum Samsung Galaxy Note 4
    Last Post: 04-22-2016, 09:36 AM
  3. Replies: 0
    Last Post: 04-21-2016, 09:40 PM
  4. Why is my Note 5 not charging properly in the car?
    Last Post: 04-21-2016, 06:48 PM
  5. Battery Question - Galaxy S6.
    Last Post: 04-21-2016, 04:58 PM
