1. rpyee's Avatar
    Verizon S7 Edge MM
    I've designated the USB as "Charging only" and now I cannot find where to access the other options to change it.
    HELP!!!
    04-22-2016 09:19 AM
  2. marlin29311's Avatar
    When you plug the phone into a computer, there is a notification that appears that says "USB for Charging only" or something similar...click on that notification and it will allow you to change over to a different protocol like MTP or other choices.
    04-22-2016 09:35 AM
  3. rpyee's Avatar
    The only message in the notification shade was "Charging". Tapping on it only took me to System info.
    04-22-2016 10:26 AM
  4. rpyee's Avatar
    SOLVED!!
    I finally got online with Samsung support and chatted with them. Turns out, I was connecting the phone to the PC using an incompatible microUSB cord. As soon as I changed cords, I was given the options in the notification shade that weren't previously there and am now able to manage my files via the computer. Hope my fix helps someone else!!
    04-22-2016 10:26 AM
  5. marlin29311's Avatar
    Glad you got it fixed!
    Almeuit likes this.
    04-22-2016 10:51 AM
  1. Replies: 2
    Last Post: 05-28-2016, 03:47 PM
  2. Calendar Not Syncing & Cant CHange Country For Google Play - Android 6
    By Robert Lindsay in forum General Help and How To
    Last Post: 05-01-2016, 08:42 AM
  3. Change CSC to allow Japanese Locale?
    By zkyevolved in forum Samsung Galaxy S7 edge
    Last Post: 04-22-2016, 04:48 AM
  4. Replies: 0
    Last Post: 04-21-2016, 08:40 PM
  5. How to change the default screen
    Last Post: 04-21-2016, 02:31 PM
