1. AR1A's Avatar
    My galaxy s7 edge is not making any sounds or vibrating only whenever i get a text message, i already checked the volumes, its not on 'Do not disturb' mode either. PLEASE HELP
    04-23-2016 06:20 PM
  2. fsfty's Avatar
    After making sure your notifications are set up correctly, did you clear the texting apps cache?
    04-23-2016 06:53 PM
  3. dmarcus48's Avatar
    Which messaging app are you using?
    04-23-2016 09:51 PM
  4. Bag of Leaves's Avatar
    Make sure your texting app isn't set to "on" in the two battery-saving areas in Settings. I have two e-mail apps that weren't notifying me until I opened them, then they would notify me the rest of the day, but the next day it would be back to not notifying me again. I had one set to "off" in one battery-saving area (the other, GMail, isn't listed in that area), but didn't know about the second area until I read a thread on here about it. I am hoping it will fix my problem.
    04-23-2016 10:28 PM
  1. factory reset please help me !!!!!
    Last Post: 04-26-2016, 03:48 PM
  2. Text will not send
    Last Post: 04-23-2016, 06:32 PM
  3. How do I get higher volume on Samsung S6
    Last Post: 04-23-2016, 06:09 PM
  4. Kies does not work with My Samsung Galaxy S4
    Last Post: 04-23-2016, 05:11 PM
