Just wondering...
1) Where did you get your Wireless Fast Charger stand?
Amazon
2) Does the stand specifically say 'Fast Charge"?
Yes. It is Samsung's fast-charge wireless stand.
3) More importantly, does the power supply t say 5v w/ 1amp and 2 amp.....or is it 9v and 5v.
It says 9V and 5V. It is the one that came with the stand and is the same type that came with the phone, including saying "Adaptive Fast Charging" on top of the plug.
If you bought it on EBay...there are a lot of vendors selling 'Fast Chargers' but it does not say Fast Charge on the stand. ANd a lot sell ones that say 'Fast Charger' but the power supply is only the 5v 2amp.
Essentually...there is
Wireless charge w/ 5v 1amp suplly
Fast charge (For the S6/ s6+) w/ 5v 2amp supply
Latest Fast Charge (for the S6 Edge+/S7/S7) w/ 5v/9v supply.
Only the stands that say Fast Charge AND have the 9v supply will truely give you fast charging.
My guess...your wired is a 9v supply but your wireless is the 5v/2amp version
I do not know if you can use the stand that says fast charge that came with the 5v/2a supply with the 5v/9v..but you can try. Just watch the heat to find out. The Latest Fast Chargers (with the 5v/9v supply) has a small fan in the base to keep it cooler.
Hope that helps.
It is a fast charge stand, with fan, with the correct plug. The box had the Samsung hologram sticker on it, too.
