I don't have "fast wireless charging" as an option in settings... only wired. I also just realized that the wireless puck ATT sold me is not of the fast charging type :-( , so i'm going to try to return.
Would the option only show if you had the correct stand/puck (doubtful)? Any ideas why I don't have the setting?
After I got my replacement (for SD card notification issue), the setting to turn off fast wireless charging was missing as well. The toggle for fast wired charging was there. After I put it on the fast wireless charger for a second to make sure it worked the setting mysteriously appeared in the settings menu. Not sure if that's by design, or not.
Okay, maybe something is wrong with my phone? I used it down to 13%, so put it on the (new) wireless stand and it calculated that it would be charged in nearly 2.5 hrs., which is what my estimate based on the trials yesterday were. I took note of what time that would be and checked it about ten minutes prior - and it was only 60% charged! Now, an hour later, so at 3.5 hours into charging, it is 85% charged. The only other thing I can think of is faulty wiring to the socket I plugged it into (different than yesterday), so tomorrow will try a different one, just in case. I more often than not used this socket to charge my S3 wired, but of course that didn't have Fast Charging. I am pretty sure that it charged slowly (old stand) on the other socket I normally use, too, but I honestly can't be 100% certain about that as I didn't start keeping track of the time when I used it.
I am a little annoyed right now! (And remember, when I tried it with the previous wireless charger while the phone was shut off, it still was slow, only a little faster than when the phone was on, so I don't think it is an app drain or anything.)
NOOOOOO... I was playing on the computer and got distracted.... So this isn't the exact time it hit 100%. From my last check I'd say it hit 100% around 11:50-11:55.
Check and make sure you don't have some app sucking power as fast as you can put it in. Recent updates to apps are always suspects because sometimes they fix a problem but create a few new ones - like excessive power consumption. I've been there many times.
I have the Samsung wireless charging stand and it charges my S7 edge very quickly (well less than an hour when under 50%)
Amazon.com: Samsung Fast Charge Wireless Charging Stand, Black: Cell Phones & Accessories
Good luck I hope they resolve the issue for youThat's exactly what I ordered (when I clicked on your link, Amazon even said I bought the item on whatever date it was). I wish mine charged as fast as yours! I need to talk with Samsung about this.
