1. Antmf's Avatar
    My screen dims when I play games how do I prevent that from happening? Thanks.
    04-25-2016 08:16 AM
  2. marlin29311's Avatar
    I would turn off auto brightness before entering the game you are playing, that would be the only way to counteract the screen dimming.
    04-25-2016 08:23 AM
  3. anon(607340)'s Avatar
    This is due to a package called "GameService" (com.enhance.gameservice)
    Download "Package Disabler Pro" from the play store and disable GameService
    This is the only way you can fix the issue. Nothing to do with autobrightness.
    04-25-2016 10:23 AM
  4. MJ Vaughn's Avatar
    06-23-2016 02:11 PM
  5. MJ Vaughn's Avatar
    This worked great. Thank you
    06-23-2016 02:12 PM
  6. Faisal6263's Avatar
    Happening same with me in xiaomi redmi 4 do you know any other name of that where can i find gameservice cuz its not present In my mobile
    04-04-2018 12:42 AM
  1. Replies: 1
    Last Post: 04-27-2016, 02:55 AM
  2. Access to pics on SD card.
    By krs123 in forum Motorola Droid Turbo 2
    Last Post: 04-25-2016, 06:37 PM
  3. How do I restore my Samsung tab 4 10.1
    Last Post: 04-25-2016, 07:40 AM
  4. Downloading images from OTG USB device (Huawei P8)
    Last Post: 04-25-2016, 07:35 AM
  5. Trouble getting answerfonr to work
    Last Post: 04-25-2016, 07:26 AM
