1. dbdmora's Avatar
    Hello, every time I try to change the sound for my ringtone or notification from settings or any app. I get an option to select an App to browse or open. It looks like I am missing the default sound selector for my unlocked S7 edge. Does anyone know how to solve it? Please help I cannot find a way to change my ringtone or notifications sounds. I cannot even select NO sound to turn off notifications for some apps.
    Attached Thumbnails I cannot select ringtones or notifications sounds on S7 edge-screenshot_20160425-103738.jpg
    04-25-2016 09:48 AM
  2. N4Newbie's Avatar
    Tap Media Storage and then (presuming it asks) tap Always.
    dbdmora likes this.
    04-25-2016 10:04 AM
  3. dbdmora's Avatar
    I feel so stupid!!! I thought it was another file explorer app. Thanks for the help.
    04-25-2016 10:11 AM
  4. N4Newbie's Avatar
    Np problem.
    With Android, if you install an app which can possibly do the thing you are looking at (apparently Go SMS Pro in this case), at the next opportunity you will be asked to choose which app to use.
    04-25-2016 10:25 AM
  1. Mark Gmail as "Read" after viewing notification?
    By 44Joan in forum Samsung Gear S2
    Last Post: 04-25-2016, 04:22 PM
  2. Why is my Galaxy s7 constantly restarting itself?
    Last Post: 04-25-2016, 09:50 AM
  3. Why do I have lines on my screen? (Developer options)
    Last Post: 04-25-2016, 09:49 AM
  4. How do i turn on the word corrector?
    Last Post: 04-25-2016, 09:46 AM
  5. forgotten pin on galaxy S6
    By luke thomas1 in forum Samsung Galaxy S6
    Last Post: 04-25-2016, 09:03 AM
