1. AC Question's Avatar
    cannot find usb charging tab on notifications setting
    04-25-2016 06:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you connect via USB, swipe down the notification panel. Do you see the USB icon there?
    You'll need to use Android File Transfer to copy the files to the Mac, but it's notoriously buggy. I would strongly recommend Google Photos Backup: https://support.google.com/photos/an...DAndroid&hl=en. If you choose High Quality (instead of Original Quality), you get unlimited cloud storage.
    04-26-2016 05:06 PM
  3. jneusch's Avatar
    You can also use OneDrive or DropBox. There is an app, iSyncr, that will sync your iTunes music and also sync photos.
    B. Diddy likes this.
    04-26-2016 10:51 PM
  4. marzfreerider's Avatar
    If your using an SD card, you can take it out then put it in the SD adapter, plug into the computer and transfer that way as well.
    04-27-2016 12:04 AM
  1. how do i screen calibrate my zte obsidian lte z820
    By AC Question in forum Other ZTE Android Phones
    Last Post: 04-26-2016, 07:29 PM
  2. Replies: 3
    Last Post: 04-26-2016, 06:03 PM
  3. Replies: 1
    Last Post: 04-26-2016, 05:23 PM
  4. Replies: 1
    Last Post: 04-26-2016, 05:11 PM
  5. How long do updates take?
    By AC Question in forum ASUS ZenFone 2
    Last Post: 04-26-2016, 04:57 PM
