1. salahpausini's Avatar
    Hi everybody.
    I'm about to buy a new smartphone but I'm still hesitating. I had an Xperia SL and I like Sony. I was going to choose the Z5 premium but some comments say the camera in the S7 edge is better. I saw some picture of the two phones and I have this impression too. Which one do you recommend me? In the Xperia SL, there were multicolour led notifications and each one has it's colour; facebook blue, SMS white, messenger green... I fear to not find this on the Samsung and the problem of the best camera. This is the only thing that prevents me from choosing.
    04-26-2016 12:42 PM
  2. mstrblueskys's Avatar
    Hi everybody.
    You're going to have to make a compromise. Both are very nice phones. Do you want the best (arguably, I'm not trying to start fights) mobile camera, or do you want A great one with different LED notifications?
    Look at the software, too. You may see something you like or dislike about either. Both a skinned pretty heavily.
    Both are going to be great phones. You're going to be happy either way. Good luck!
    04-26-2016 12:46 PM
  3. salahpausini's Avatar
    Thank you for answering!
    I want both, led notifications and a good camera, lol. Does the S7 edge have the led multicolour notifications? Which one do you prefer?
    04-26-2016 01:29 PM
  4. LanceAllan's Avatar
    on the s7 it is app dependent.. if the app you are using gives the option to change the led you can change it
    04-26-2016 01:32 PM
  5. LanceAllan's Avatar
    For instance my texts are yellow, Android Central is green, Gmail is blue and so on, so the ability is there...
    Sent from my Adamantium™ S7 edge
    04-26-2016 01:34 PM
  6. salahpausini's Avatar
    In Xperia SL it's integrated, it's not an application, and it works better than the applications. Samsung?
    04-26-2016 01:43 PM
  7. LanceAllan's Avatar
    i'm not sure how it works better... i think with a light color either it works or it doesn't.... if you like the internal feature i would just go with the Xperia then, it's nice phone
    salahpausini likes this.
    04-26-2016 01:47 PM
  8. salahpausini's Avatar
    Thank you. The cameras?
    04-26-2016 01:54 PM
  9. LanceAllan's Avatar
    the camera on the s7 is hard to beat, the focus time and low light ability is pretty outstanding... that being said it is a sony sensor (lol) i personally would pick the edge, but i don't think you can be disappointed either way
    04-26-2016 01:58 PM
  10. LanceAllan's Avatar
    04-26-2016 02:02 PM
  1. Can Acer Iconia A1 840fhd upgraded to Lollipop or Marshmallow?
    By Rutz1104 in forum General Help and How To
    Last Post: 04-29-2016, 10:17 AM
  2. Z5 premium or s7 edge? HELP!
    By salahpausini in forum Sony Xperia Z5 Premium
    Last Post: 04-28-2016, 01:59 PM
  3. Replies: 1
    Last Post: 04-26-2016, 03:04 PM
  4. Could I have knocked something loose when I dropped my Sony Xperia Z5 Compact?
    By AC Question in forum Sony Xperia Z5 & Z5 Compact
    Last Post: 04-26-2016, 12:16 PM
