08-09-2018 10:10 AM
47 12
tools
  1. AC Question's Avatar
    I noticed that games are very laggy on my phone so i decided to download the AnTuTu benchmark and see what's up. And to no surprise it shows a score of around 95000 which is very low compared to the 120000+ i see on youtube.
    Its the Exynos version btw and yea i tried restarting and retesting.
    04-26-2016 02:51 PM
  2. Javier P's Avatar
    Welcome to the forums! Have you enabled any battery saving mode?
    B. Diddy likes this.
    04-26-2016 03:05 PM
  3. trysis3's Avatar
    i had app power saving on but nothing else. I closed it and im still getting the same score.
    04-26-2016 03:23 PM
  4. mstrblueskys's Avatar
    Or are you running any add blockers or battery optimizers?
    04-26-2016 03:27 PM
  5. trysis3's Avatar
    i am not using either unfortunately..
    04-26-2016 03:33 PM
  6. Javier P's Avatar
    What about an antivirus or RAM booster? You could try a cache partition wipe via recovery mode and see if it helps.
    04-26-2016 03:42 PM
  7. mstrblueskys's Avatar
    Yeah, I'd guess you have some program bogging your system down. Even Snapchat does this to me on occasion. Go into Settings>Apps and see if anything is running.
    04-26-2016 03:54 PM
  8. trysis3's Avatar
    i have no boosters or antivirus and i just wiped the cache. Will retest and update.
    i just went to developer settings and limited background apps to none. Will retest and update.
    04-26-2016 04:07 PM
  9. trysis3's Avatar
    ok just retested after shutting down everything and i got a 93000 score, fml. Could it be a hardware problem ?
    04-26-2016 04:09 PM
  10. mstrblueskys's Avatar
    Try *#*#2432546#*#* in your phone dialer, wait a few minutes, and rerun. See if that helps.
    04-26-2016 04:10 PM
  11. trysis3's Avatar
    i typed the number and nothing is happening
    04-26-2016 04:19 PM
  12. mstrblueskys's Avatar
    Did nothing happen or did it disappear?
    04-26-2016 04:28 PM
  13. trysis3's Avatar
    nothing happens. Anyway im thinking about factory reseting, would you advise against it ?
    04-26-2016 04:52 PM
  14. mstrblueskys's Avatar
    Might be worth a shot if you don't mind restoring the phone. Get it all back up and running and reboot it a few times to be sure before checking anything.
    04-26-2016 04:57 PM
  15. trysis3's Avatar
    what do you mean by reboot it ? like after the reset ?
    04-26-2016 05:01 PM
  16. mstrblueskys's Avatar
    Yeah, I've noticed that after I do something dramatic (like update or reset), if I restart the device 4-5 times, it works better than if I were to just go for it!
    04-26-2016 05:10 PM
  17. trysis3's Avatar
    alright factory reseted, rebooted, installed antutu, wiped cache. Time to test, will update..
    04-26-2016 05:57 PM
  18. trysis3's Avatar
    alright i got 103000 after the factory reset, what to do now ?
    04-26-2016 06:10 PM
  19. Javier P's Avatar
    That sounds practically normal for the Exynos model.
    http://www.phonearena.com/news/AnTuT...ersion_id78364
    04-26-2016 06:20 PM
  20. danlnyc's Avatar
    I just ran a benchmark and my phone came out to be 91K.....
    Did I receive a defective S7?
    I have the US spec version for Verizon
    04-26-2016 08:24 PM
  21. LanceAllan's Avatar
    Not sure I have a Verizon s7 edge and get 133610....
    Sent from my Adamantium™ S7 edge
    04-26-2016 09:11 PM
  22. Str0ntium's Avatar
    I got 129922 on a VZW S7.
    04-26-2016 09:24 PM
  23. trysis3's Avatar
    AnTuTu: Galaxy S7 with Snapdragon GPU scores 20% higher than the Exynos version
    i don't think this information is accurate, since i got 117000 at one point and others have got even higher.
    04-27-2016 04:20 AM
  24. trysis3's Avatar
    do you notice bad performance during games?
    is that the Exynos version ?
    04-27-2016 04:22 AM
  25. LanceAllan's Avatar
    No its the snapdragon
    04-27-2016 07:52 AM
47 12
  1. Question on Gear S with Sprint
    By AC Question in forum Samsung Gear S
    Last Post: 05-09-2016, 07:31 PM
  2. Why is my phones memory getting deleted when my battery dies
    Last Post: 04-26-2016, 06:08 PM
  3. Calendar notifications while on calls - Galaxsy S6
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-26-2016, 06:03 PM
  4. Marshmallow has killed my wifi
    Last Post: 04-26-2016, 03:34 PM
  5. Replies: 5
    Last Post: 04-26-2016, 02:43 PM
