1. person1001's Avatar
    So I tried modern combat 5 ,the runs very smooth no lag no issues but I get 1 stutter each level, is this normal? Does the game load when stutter occur? or maybe bad WiFi connection?
    04-26-2016 04:47 PM
  2. neonworm's Avatar
    What do you mean by 1 stutter? Do you mean exactly one stutter each level? If so, does it happen at the same time every time?
    04-26-2016 04:57 PM
  3. person1001's Avatar
    Thanks for your reply, yes I mean exactly 1 stutter, well I can't say for sure it happens at the same time every time, but I can say that it happens at the beginning of each level ( maybe after 2 mins of playing)
    I just tried multiplayer, in 5 mins match stutter occurred 3 times is this normal?
    04-26-2016 05:28 PM
  4. xocomaox's Avatar
    Most games are very poorly coded and/or ported. So I would not be surprised as they are not going to be optimized for your hardware since there are so many configurations for Android phones.
    person1001 likes this.
    04-26-2016 07:32 PM
  5. person1001's Avatar
    Thank u so much
    04-26-2016 08:42 PM
  1. Replies: 6
    Last Post: 05-14-2016, 08:16 AM
  2. Replies: 5
    Last Post: 05-13-2016, 07:24 AM
  3. How do I prevent data loss with a factory reset on my S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-26-2016, 05:03 PM
  4. No Video, Sound only in all Video Players
    By lifress in forum Samsung Galaxy S6 active
    Last Post: 04-25-2016, 04:08 PM
