06-06-2017 07:30 PM
31 12
tools
  1. navionics's Avatar
    Until recently I was a proud owner of Samsung S7 SM-G930FD. Dual sim problem was going on for some time until I completely lost reception on SIM # 2. With little research I found out that as long as I select 4G on either SIM, that sim will work on that particular network. SIM downgraded to 2Gt will not get any voice or data.
    Found out that companies such as AT&T have completely cut of voice channels and strumming voice via 4G or 3G. Since the Galaxy 7S duo can have only one SIM on 4G the other SIM becomes useless. Another word, If Samsung does not do anything to change in the Galaxy S7 software the duos are useless in US.
    Open for suggestions and/or tips.
    01-27-2017 01:11 PM
  2. Freakster1's Avatar
    Hey do any of you that own the Dual sim version of this phone have a symbol beside the words Sim in the sim cards settings menu? Was looking at a used one and thought that was out of the ordinary... Im just trying to avoid getting a fake....
    02-19-2017 09:39 AM
  3. Freakster1's Avatar
    ok so I found that it is actually the Chinese symbol for Sim. I have not seen it in all the pictures I saw online in the sim settings.... Is this normal and does this indicate the phone was sourced from China?
    02-19-2017 01:19 PM
  4. ojosilva's Avatar
    I have the same problem.
    I'm in Spain with a primary Spanish provider sim and have a secondary US T-mobile sim and that sim presents the same issue with my dual sim phone (Galaxy J5 J500F) and a friends dual sim (Galaxy J510FN). Just by introducing the tmobile SIM card paired with any other sim card (any slot) will reproduce the issue: the 4g data connection provided by the non-tmobile sim card disconnects after only a few minutes since rebooting. Also going to airplane mode, switching sims or getting out of a wifi range will trigger the problem. This started with the first Android 6.0 update for the galaxy J5. The last update I got, just a week ago for Android 6.0.1 has the same issue. Making the tmobile roaming data service the primary selected data service is the only way I can get data in my phone and have both sims active. Also, disabling the tmobile sim and using only my Spanish provider data service will also work.
    I've tried all sorts of combinations, sim slots, connection and APN configuration to no results in the last few months. I factory reset and tested the tmobile sim in other phones. The problem is deeply embedded in Samsung devices + Android 6.x combination. Apparently the same problem happens if you flash a Cyanogenmod ROM based in Android 6 (Marshmallow). I concluded the problem is not present with either Android 5.1.1 Lollipop (J5 stock) or Android 7.x Nougat.
    So I decided to dig deeper into the problem and rooted my J5 phone. I tinkled with configuration files in the /data directory. I also took a few log file "snaphots" from when the problem presents itself. The phone is initially connected to the primary SIM network, which is NOT tmobile. Then in a span of 10 seconds it disconnects the data. See the log below. My theory is that it has something to do with the way the tmobile sim info is setup, how the Samsung hardware interprets it and how that interferes with Android 6 dualsim phone management software layer. But I just can't nail it. Maybe someone more experienced with android internals can recognize the problem from the log below.
    Code:
    02-20 21:24:37.911  7478  7478 D StatusChecker: onReceive : android.intent.action.SERVICE_STATE
    02-20 21:24:37.911  7478  7478 D StatusChecker: onReceive : SIMChangeAlertOption disabled return
    02-20 21:24:37.911  3556  4748 D MediaProvider: restoreSdcardContents started
    02-20 21:24:37.921  2072  3513 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{96b6e40 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a1577e8 7262:com.samsung.android.SettingsReceiver/1000}
    02-20 21:24:37.921  4929  4929 D FactoryTestApp: [IPCWriterToSecPhoneService$handleMessage](4929) Send BOOTING COMPLETED done
    02-20 21:24:37.921   909  2079 D AT_Distributor: Send Msg [RIL > ATD] 19 bytes <BOOTING COMPLETED(\r)(\n)>
    02-20 21:24:37.921  3556  4748 D MediaProvider: files_backup table does not have data for 1664573798
    02-20 21:24:37.931  2072  3331 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{96b6e40 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{98d865b 7448:com.sec.android.widgetapp.dualsimwidget/1001}
    02-20 21:24:37.931  3556  4748 D MediaProvider: savePlaylistTableInBulkDeleter started
    02-20 21:24:37.931  3556  4748 D MediaProvider: savePlaylistTableInBulkDeleter started - audio_playlists_map_personal_cache existed
    02-20 21:24:37.931  3556  4748 D MediaProvider: savePlaylistTableInBulkDeleter started - audio_playlists_map_personal_cache is empty
    02-20 21:24:37.941  6322  6457 I Icing   : Indexing BC793E5DEBD4F464DE8341658CB6DD5D2E3CD355 from com.google.android.gms
    02-20 21:24:37.961  2072  2088 I art     : Background partial concurrent mark sweep GC freed 50087(2MB) AllocSpace objects, 1(60KB) LOS objects, 33% free, 28MB/43MB, paused 3.847ms total 211.485ms
    02-20 21:24:37.961  6322  6457 I Icing   : Indexing done BC793E5DEBD4F464DE8341658CB6DD5D2E3CD355
    02-20 21:24:37.971  2072  3338 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{96b6e40 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{f92acca 7478:com.sec.android.app.mt/1000}
    02-20 21:24:37.971  7478  7478 D StatusChecker: onReceive : android.intent.action.SERVICE_STATE
    02-20 21:24:37.971  7478  7478 D StatusChecker: onReceive : SIMChangeAlertOption disabled return
    02-20 21:24:37.981  2072  2101 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{3d5a179 u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:37.981  2072  3267 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{5becebe u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:37.991  2072  3278 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{a301b1f u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:37.991  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget: {[9C41A2EAFAAB2EF4F8363256C22FE8ADC05C1B1077ADBDFCD26E0DD65F89F33B4FE17DC1B474497D31FC899B742F59FC7E2530D44AA0E0C337CE79DB8742B2E258F6CB339704D31C42A8D7DC7C423413771689541177F15128C5082E60F137378548A4A3E3BC46E58400842019503B6A49C8E5B66CD635265353D3A3BD633961]}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  : {[15C09394A4E9AFE55A5C62F22AB3FC5902EB2A2150B6646A86F2B3102D669614]}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  : {[2A0107660AADCC4E2A961AE9FB23F31D383D83030A1346F911A97956E85399BAE6C8229C4AFF2FDEBD71F58F001E9D461E38ED93181759A059B562C6094AC289215B67A59E00AD30470DB1D36C8A9D0965BAEE47DC0D014AE914D42684AA8906080588AE26A7F1768D441FAD5C9D475C]}
    02-20 21:24:38.001  2072  3257 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{a301b1f u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget2x1: {[9C41A2EAFAAB2EF4F8363256C22FE8AD1E8C40D052B00F217143F036334087D4E6A20622B7C5BAFDDAD05806F64279CFB58ACC644B946D1D44C1CB1343E9933E78640F20943B210E98A310C2B6492635456F7A98A5575530AC106B72D841268FE4ABD25C67426FA9138DA38B471E495644FE77123B7000FBE859923F0050324E]}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  : {[AA0F1FFBE590A9EFC37054BD5EE30C3F13AAEFB0C1D46CFF1BAA5F3C6AC68B331A2EF1B485217118DBE54FFA6A88B711AC7C94EA741B05F20DACF9DE9722647F]}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget2x1: {[9C41A2EAFAAB2EF4F8363256C22FE8AD176C2E70281622FE10C55CE4F020D91847EBF4B34973709DA9F468F8024D59099B1123845E09A0FAC59473FA9ED60953]}
    02-20 21:24:38.001  2072  3512 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{a301b1f u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:38.001  7357  7357 D [WeatherWidget(1220)]  EasyWeatherAppWidget: {[48948B2BE5213A6D5B0C9B7747497512D204533BF333E4D2CEAD653C68E1B222E4748640A665E8FB625C2496224988A01822F94E1D5511EDA528C1BE4CAEABD1D9C6A4F90F6430CF4A4F5AB6F2AF9127520AD0A30D99495D03E7BBCB8D48F747F2FF12B441DB9FDD66804D1185ECF265D727A94D84DA9FC743DD76C54F03F188]}
    02-20 21:24:38.011  7357  7357 D [WeatherWidget(1220)]  : {[AA0F1FFBE590A9EFC37054BD5EE30C3F13AAEFB0C1D46CFF1BAA5F3C6AC68B331A2EF1B485217118DBE54FFA6A88B711AC7C94EA741B05F20DACF9DE9722647F]}
    02-20 21:24:38.011  7357  7357 D [WeatherWidget(1220)]  EasyWeatherAppWidget: {[48948B2BE5213A6D5B0C9B774749751274237807901AA8393F0A8526192EEF19F2D7E71ABBE368E57B1937778E7A2758BD22312FFA1C721753FCFDC0AD054D98]}
    02-20 21:24:38.011  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{7b92e6c u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.021  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{985dc35 u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.021  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{d1518ca u0 com.android.mail.ACTION_NOTIFY_DATASET_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{7166ad0 8200:com.google.android.gm/u0a82}
    02-20 21:24:38.031   909  2079 D AT_Distributor: SetAtdStatus(), 1_1_0
    02-20 21:24:38.031   909  2079 D AT_Distributor: Send Msg [ATD > UART] 19 bytes <BOOTING COMPLETED(\r)(\n)>
    02-20 21:24:38.041  2072  3257 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{640c558 u0 com.android.mail.ACTION_NOTIFY_DATASET_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{7166ad0 8200:com.google.android.gm/u0a82}
    02-20 21:24:38.051  2072  3257 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{fc506b1 u0 com.google.android.gm.intent.ACTION_PROVIDER_CREATED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{7166ad0 8200:com.google.android.gm/u0a82}
    02-20 21:24:38.091  2072  3267 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{fb44f17 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a1577e8 7262:com.samsung.android.SettingsReceiver/1000}
    02-20 21:24:38.101  2072  3512 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{fb44f17 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{98d865b 7448:com.sec.android.widgetapp.dualsimwidget/1001}
    02-20 21:24:38.131  2072  3192 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{fb44f17 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{f92acca 7478:com.sec.android.app.mt/1000}
    02-20 21:24:38.131  7478  7478 D StatusChecker: onReceive : android.intent.action.SERVICE_STATE
    02-20 21:24:38.131  7478  7478 D StatusChecker: onReceive : SIMChangeAlertOption disabled return
    02-20 21:24:38.131  2072  3074 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{2a8df04 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a1577e8 7262:com.samsung.android.SettingsReceiver/1000}
    02-20 21:24:38.141  2072  3278 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{2a8df04 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{98d865b 7448:com.sec.android.widgetapp.dualsimwidget/1001}
    02-20 21:24:38.161  2072  3278 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{2a8df04 u-1 android.intent.action.SERVICE_STATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{f92acca 7478:com.sec.android.app.mt/1000}
    02-20 21:24:38.161  7478  7478 D StatusChecker: onReceive : android.intent.action.SERVICE_STATE
    02-20 21:24:38.161  7478  7478 D StatusChecker: onReceive : SIMChangeAlertOption disabled return
    02-20 21:24:38.171  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{6f25ced u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.171  2072  2686 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{9cff722 u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.181  2072  2686 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{124c5b3 u0 android.intent.action.PROVIDER_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.191  3556  4748 D MediaProvider: savePlaylistTableInBulkDeleter finished
    02-20 21:24:38.191  2072  3257 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{124c5b3 u0 android.intent.action.PROVIDER_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.191  3556  4748 D MediaScanner: getExternalStorageSdPath :  /storage/6337-6166
    02-20 21:24:38.211  2072  3512 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{124c5b3 u0 android.intent.action.PROVIDER_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.211  2072  3278 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{c24dae9 u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.221  2072  2698 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{f9a636e u0 com.android.mail.ACTION_NOTIFY_DATASET_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{7166ad0 8200:com.google.android.gm/u0a82}
    02-20 21:24:38.231  3249  3249 V LauncherAppWidgetHostView: calculateWidgetSize: (target widgetsize)  using w/h 686 910 span 4 4 (widgetid 9) [current Gridsize : GRID_4x4]
    02-20 21:24:38.231  3249  3249 D LauncherAppWidgetHostView: calculateWidgetSize() widget = Schedule(widget id = 9) result hostview size = 686 x 910
    02-20 21:24:38.231  3249  3249 D LauncherAppWidgetHostView: setResizeScaleResult() 686/ 910 scaleToResize = 1.0(widget id = 9)
    02-20 21:24:38.231  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{19b0a9c u-1 android.telecom.action.PHONE_ACCOUNT_REGISTERED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{2589474 3116:android.process.acore/u0a7}
    02-20 21:24:38.241  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{ce73ca5 u0 com.google.android.gms.icing.action.CONTACT_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{6b0c490 3620:com.google.android.gms.persistent/u0a10}
    02-20 21:24:38.251  3556  4748 D MediaScanner: Prescan. DB items number : 12594 DB_FILES_NUMBER_CACHING_LIMITATION : 7000  Caching mode : false
    02-20 21:24:38.251  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{f8d487a u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:38.261  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget: {[9C41A2EAFAAB2EF4F8363256C22FE8ADC05C1B1077ADBDFCD26E0DD65F89F33B4FE17DC1B474497D31FC899B742F59FC7E2530D44AA0E0C337CE79DB8742B2E258F6CB339704D31C42A8D7DC7C423413771689541177F15128C5082E60F137378548A4A3E3BC46E58400842019503B6A49C8E5B66CD635265353D3A3BD633961]}
    02-20 21:24:38.261  7357  7357 D [WeatherWidget(1220)]  : {[15C09394A4E9AFE55A5C62F22AB3FC5902EB2A2150B6646A86F2B3102D669614]}
    02-20 21:24:38.271  7357  7357 D [WeatherWidget(1220)]  : {[2A0107660AADCC4E2A961AE9FB23F31D383D83030A1346F911A97956E85399BAE6C8229C4AFF2FDEBD71F58F001E9D461E38ED93181759A059B562C6094AC289215B67A59E00AD30470DB1D36C8A9D0965BAEE47DC0D014AE914D42684AA8906080588AE26A7F1768D441FAD5C9D475C]}
    02-20 21:24:38.271  2072  3267 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{f8d487a u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:38.271  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget2x1: {[9C41A2EAFAAB2EF4F8363256C22FE8AD1E8C40D052B00F217143F036334087D4E6A20622B7C5BAFDDAD05806F64279CFB58ACC644B946D1D44C1CB1343E9933E78640F20943B210E98A310C2B6492635456F7A98A5575530AC106B72D841268FE4ABD25C67426FA9138DA38B471E495644FE77123B7000FBE859923F0050324E]}
    02-20 21:24:38.271  7357  7357 D [WeatherWidget(1220)]  : {[AA0F1FFBE590A9EFC37054BD5EE30C3F13AAEFB0C1D46CFF1BAA5F3C6AC68B331A2EF1B485217118DBE54FFA6A88B711AC7C94EA741B05F20DACF9DE9722647F]}
    02-20 21:24:38.271  7357  7357 D [WeatherWidget(1220)]  WeatherAppWidget2x1: {[9C41A2EAFAAB2EF4F8363256C22FE8AD176C2E70281622FE10C55CE4F020D91847EBF4B34973709DA9F468F8024D59099B1123845E09A0FAC59473FA9ED60953]}
    02-20 21:24:38.281  3116  3234 E ContactsProvider_EventLog: Flush buffer to file cnt : 4 size : 20Kb duration : 20ms lastUpdatedAfter : 2242 ms mFlush_time_threasold : 2420 mCurrentSize : 10446
    02-20 21:24:38.281  2072  3257 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{f8d487a u0 com.sec.android.widgetapp.ap.hero.accuweather.widget.action.WEATHER_SCREEN_ON qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{a37df4a 7357:com.sec.android.daemonapp/u0a125}
    02-20 21:24:38.281  7357  7357 D [WeatherWidget(1220)]  EasyWeatherAppWidget: {[48948B2BE5213A6D5B0C9B7747497512D204533BF333E4D2CEAD653C68E1B222E4748640A665E8FB625C2496224988A01822F94E1D5511EDA528C1BE4CAEABD1D9C6A4F90F6430CF4A4F5AB6F2AF9127520AD0A30D99495D03E7BBCB8D48F747F2FF12B441DB9FDD66804D1185ECF265D727A94D84DA9FC743DD76C54F03F188]}
    02-20 21:24:38.281  7357  7357 D [WeatherWidget(1220)]  : {[AA0F1FFBE590A9EFC37054BD5EE30C3F13AAEFB0C1D46CFF1BAA5F3C6AC68B331A2EF1B485217118DBE54FFA6A88B711AC7C94EA741B05F20DACF9DE9722647F]}
    02-20 21:24:38.281  7357  7357 D [WeatherWidget(1220)]  EasyWeatherAppWidget: {[48948B2BE5213A6D5B0C9B774749751274237807901AA8393F0A8526192EEF19F2D7E71ABBE368E57B1937778E7A2758BD22312FFA1C721753FCFDC0AD054D98]}
    02-20 21:24:38.291  2072  3331 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{399382b u0 com.google.android.gms.gcm.ACTION_SCHEDULE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{6b0c490 3620:com.google.android.gms.persistent/u0a10}
    02-20 21:24:38.291  2072  3331 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{39c3488 u0 com.google.android.calendar.APPWIDGET_NEXT_UPDATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.301  2072  2698 V AlarmManager:  remove PendingIntent] PendingIntent{ab3fe21: PendingIntentRecord{af474b5 com.google.android.calendar broadcastIntent}}
    02-20 21:24:38.301  2072  2102 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{4977246 u0 com.google.android.calendar.APPWIDGET_NEXT_UPDATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.301  2072  3027 V AlarmManager:  remove PendingIntent] PendingIntent{1712c07: PendingIntentRecord{af474b5 com.google.android.calendar broadcastIntent}}
    02-20 21:24:38.311  2072  3512 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{d041134 u0 com.google.android.calendar.APPWIDGET_NEXT_UPDATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.311  2072  3513 V AlarmManager:  remove PendingIntent] PendingIntent{a315b5d: PendingIntentRecord{af474b5 com.google.android.calendar broadcastIntent}}
    02-20 21:24:38.321  2072  3338 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{7c86cd2 u0 android.intent.action.MEDIA_SCANNER_FINISHED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{1d60e0a 4749:com.sec.android.gallery3d/u0a34}
    02-20 21:24:38.331  4749  4749 D MediaStatusReceiver: Received action[android.intent.action.MEDIA_SCANNER_FINISHED]
    02-20 21:24:38.341  2072  4331 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{dea81a3 u0 com.android.mail.ACTION_NOTIFY_DATASET_CHANGED qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{7166ad0 8200:com.google.android.gm/u0a82}
    02-20 21:24:38.351  2072  3278 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{a2d5059 u0 com.google.android.calendar.APPWIDGET_REFRESH_MODEL qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.351  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.361  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.361  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.391  2072  3512 V AlarmManager:  remove PendingIntent] PendingIntent{19c841e: PendingIntentRecord{61e14c com.google.android.calendar broadcastIntent}}
    02-20 21:24:38.401  3249  7381 D ViewSystem: updateTemporaryMetaData() has done.
    02-20 21:24:38.401  3249  7381 D ViewSystem: updateRemoteViews(0) has done.
    02-20 21:24:38.401  2072  4331 V BroadcastQueue: [background] Process cur broadcast BroadcastRecord{d1994ff u0 com.google.android.calendar.APPWIDGET_NEXT_UPDATE qIdx=4}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{5170c66 7151:com.google.android.calendar/u0a83}
    02-20 21:24:38.411  2072  3513 V AlarmManager:  remove PendingIntent] PendingIntent{b8452cc: PendingIntentRecord{af474b5 com.google.android.calendar broadcastIntent}}
    02-20 21:24:38.411  3249  7381 D ViewSystem: updateRemoteViews(1) has done.
    02-20 21:24:38.421  3249  7381 D ViewSystem: updateRemoteViews(2) has done.
    02-20 21:24:38.421  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.431  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.431  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.431  3249  7381 D ViewSystem: updateRemoteViews(3) has done.
    02-20 21:24:38.441  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.441  3249  7381 D ViewSystem: updateRemoteViews(4) has done.
    02-20 21:24:38.441  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.451  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.451  3249  7381 D ViewSystem: updateRemoteViews(5) has done.
    02-20 21:24:38.451  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.461  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.461  3249  7381 D ViewSystem: updateRemoteViews(6) has done.
    02-20 21:24:38.461  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.471  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.481  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.481  3249  7381 D ViewSystem: updateRemoteViews(7) has done.
    02-20 21:24:38.481  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.481  3249  7381 D ViewSystem: updateRemoteViews(8) has done.
    02-20 21:24:38.491  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.491  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.491  3249  7381 D ViewSystem: updateRemoteViews(9) has done.
    02-20 21:24:38.501  3249  7381 D ViewSystem: updateRemoteViews(10) has done.
    02-20 21:24:38.511  2072  3278 D EnterpriseDeviceManagerService: isManagedProfileUser(): userId = 0
    02-20 21:24:38.511  2072  3278 E PhoneRestrictionPolicy: getEmergencyCall >>false
    02-20 21:24:38.511  2072  4331 D EnterpriseDeviceManagerService: isManagedProfileUser(): userId = 0
    02-20 21:24:38.521  2072  3513 D EnterpriseDeviceManagerService: isManagedProfileUser(): userId = 0
    02-20 21:24:38.521  3249  7381 D ViewSystem: updateRemoteViews(11) has done.
    02-20 21:24:38.521  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.521  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.531  2772  3042 D TP/SmsProvider: insert, match:15, calling pid = 2772
    02-20 21:24:38.531  2772  3042 D TP/SmsProvider: insertInner match = 15
    02-20 21:24:38.531  3249  7381 D ViewSystem: updateRemoteViews(12) has done.
    02-20 21:24:38.531  2772  3042 D SmsProvider: insert content://raw/1 succeeded
    02-20 21:24:38.531  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.531  2772  3042 I TP/MmsSmsProvider: notifyChange mms-sms
    02-20 21:24:38.541  2772  3042 D TP/SmsProvider: insert, match 15:Elapsed time : 9.037 ms
    02-20 21:24:38.541  3249  3249 V LauncherAppWidgetHostView: calculateWidgetSize: (target widgetsize)  using w/h 686 910 span 4 4 (widgetid 9) [current Gridsize : GRID_4x4]
    02-20 21:24:38.541  3249  3249 D LauncherAppWidgetHostView: calculateWidgetSize() widget = Schedule(widget id = 9) result hostview size = 686 x 910
    02-20 21:24:38.541  3249  3249 D LauncherAppWidgetHostView: setResizeScaleResult() 686/ 910 scaleToResize = 1.0(widget id = 9)
    02-20 21:24:38.551  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.561  3249  7381 D ViewSystem: updateRemoteViews(13) has done.
    02-20 21:24:38.561  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.561  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.571  3249  7381 D ViewSystem: updateRemoteViews(19) has done.
    02-20 21:24:38.571  2772  3042 V GsmInboundSmsHandler: Unable to find carrier package: [], nor systemPackages: []
    02-20 21:24:38.581  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10146, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.581  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10022, mScreenOn: true, uidstate: 10, mProxSensorScreenOff: false
    02-20 21:24:38.581  3249  7381 D ViewSystem: updateRemoteViews(15) has done.
    02-20 21:24:38.581  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.591  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.591  2072  2293 V BroadcastQueue: [foreground] Process cur broadcast BroadcastRecord{408c42a u0 android.intent.action.DATA_SMS_RECEIVED qIdx=2}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{1156569 2772:com.android.phone/1001}
    02-20 21:24:38.591  3249  7381 D ViewSystem: updateRemoteViews(18) has done.
    02-20 21:24:38.601  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.601  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.601  3249  7381 D ViewSystem: updateRemoteViews(17) has done.
    02-20 21:24:38.601  2772  2772 V OmtpMessageReceiver: Received vvm message : true
    02-20 21:24:38.601  2772  2772 D OmtpSmsParser: parse sms prefix VVM : //VVM:STATUS:st=R;rc=0;srv=vvm.tmomail.net;ipt=143;u=5555555@vms.eng.t-mobile.com;pw=k8USEjou;lang=1|2|3|4;g_len=180;vs_len=10;pw_len=4-9
    02-20 21:24:38.611  2772  2772 V OmtpMessageReceiver: Received STATUS sms for
    02-20 21:24:38.621  3249  7381 D ViewSystem: updateRemoteViews(14) has done.
    02-20 21:24:38.621  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.631  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 3, mProxSensorScreenOff: false
    02-20 21:24:38.631  3249  7381 D ViewSystem: updateRemoteViews(16) has done.
    02-20 21:24:38.631  8200  8225 I GAV2    : Thread[GAThread,5,main]: No campaign data found.
    02-20 21:24:38.641  3249  7381 D ViewSystem: updateRemoteViews(20) has done.
    02-20 21:24:38.641  2072  2718 D NetworkPolicy: isUidForegroundLocked: 10025, mScreenOn: true, uidstate: 16, mProxSensorScreenOff: false
    02-20 21:24:38.681  2072  3339 V AlarmManager:  remove PendingIntent] PendingIntent{9c7b191: PendingIntentRecord{946f8f6 com.android.phone startService}}
    02-20 21:24:38.681  2072  2102 V AlarmManager:  remove PendingIntent] PendingIntent{75724f7: PendingIntentRecord{b682f64 com.android.phone startService}}
    02-20 21:24:38.681  2072  3027 V AlarmManager:  remove PendingIntent] PendingIntent{524d5cd: PendingIntentRecord{361ae82 com.android.phone startService}}
    02-20 21:24:38.681  2772  2772 I NotificationMgr: updateMwi(): subId 2 update to false
    02-20 21:24:38.681  2772  2772 D NotificationMgr: sendClearVoicemailInfo()...
    02-20 21:24:38.691  4377  4377 D Mms/SmsReceiver: filterMsgServiceIntent : intent.getAction() : android.intent.action.DATA_SMS_RECEIVED
    02-20 21:24:38.691  2072  3331 V BroadcastQueue: [foreground] Process cur broadcast BroadcastRecord{408c42a u0 android.intent.action.DATA_SMS_RECEIVED qIdx=2}, state= (APP_RECEIVE) DELIVERED for app ProcessRecord{efa4e7a 4377:com.android.mms/u0a55}
    02-20 21:24:38.701  2772  8370 V OmtpVvmSyncService: Sync requested: full_sync - for account: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e6d0313050bbc8a63dd632550bfd9addb795850d], UserHandle{0}
    02-20 21:24:38.711  2772  8370 D ConnectivityManager: requestNetwork; getAppId(CallingUid) : 1001, CallingPid : 2772
    02-20 21:24:38.711  2772  3042 D TP/SmsProvider: delete, uri=content://sms/raw, calling pid = 2772
    02-20 21:24:38.721  4377  4377 D Mms/SmsReceiverService: onStart: #1 , mResultCode: 0 = Unknown error code, action = android.intent.action.DATA_SMS_RECEIVED
    02-20 21:24:38.721  4377  8371 D Mms/TelephonyPermission: mUserId = 0
    02-20 21:24:38.721  4377  8371 D Mms/TelephonyPermission: isDefault true
    02-20 21:24:38.721  4377  8371 D Mms/SmsReceiverService: [SMS]Receiver handleMessage : Action =android.intent.action.DATA_SMS_RECEIVED
    02-20 21:24:38.721  2772  3042 D SmsProvider: delete deletedRows=1
    02-20 21:24:38.721  2772  3042 I TP/MmsSmsProvider: notifyChange mms-sms
    02-20 21:24:38.721  2772  3042 D TP/SmsProvider: delete, uri=content://sms/raw:Elapsed time : 10.313 ms
    02-20 21:24:38.721  2072  3513 D ConnectivityManager: enforceChangePermission: calling uid (1001)
    02-20 21:24:38.731  2072  3513 D ConnectivityService: requestNetwork for Request from uid/pid:1001/2772 for NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ]
    02-20 21:24:38.731  2072  2723 D ConnectivityService: rematching NetworkAgentInfo [MOBILE (HSPA+) - 501]
    02-20 21:24:38.731  2072  2723 D ConnectivityService:  network has: NetworkAgentInfo{ ni{[type: MOBILE[HSPA+] - MOBILE, state: CONNECTED/CONNECTED, reason: (unspecified), extra: gprs.pepephone.com, roaming: false, failover: false, isAvailable: true]}  network{501}  lp{{InterfaceName: rmnet_data0 LinkAddresses: [10.75.22.159/32,]  Routes: [0.0.0.0/0 -> 10.75.22.160 rmnet_data0,] DnsAddresses: [80.58.61.250,80.58.61.254,] Domains: null MTU: 0 TcpBufferSizes: 31455,131070,1830912,6144,24576,1830912}}  nc{[ Transports: CELLULAR Capabilities: MMS&SUPL&DUN&FOTA&IMS&CBS&IA&XCAP&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&BIP LinkUpBandwidth>=11264Kbps LinkDnBandwidth>=43008Kbps Specifier: <1>]}  Score{50}  everValidated{true}  lastValidated{true}  created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} }
    02-20 21:24:38.731  2072  2723 D ConnectivityService: Network NetworkAgentInfo [MOBILE (HSPA+) - 501] was already satisfying request 1. No change.
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] satisfies: false nri.isRequest: true
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=4, legacyType=-1, [ Transports: WIFI Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] satisfies: false nri.isRequest: false
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=7, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] satisfies: true nri.isRequest: false
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=3, legacyType=-1, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] satisfies: true nri.isRequest: false
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=6, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED] ] satisfies: true nri.isRequest: false
    02-20 21:24:38.731  2072  2723 D ConnectivityService:   checking if request is: NetworkRequest [ id=5, legacyType=-1, [] ] satisfies: true nri.isRequest: false
    02-20 21:24:38.731  2072  2723 D ConnectivityService: sending new Min Network Score(0): NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ]
    02-20 21:24:38.731  2072  2720 D WIFI_UT : got request NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] with score 0
    02-20 21:24:38.731  2072  2720 D WIFI_UT :   my score=2147483647, my filter=[ Transports: WIFI Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=1048576Kbps LinkDnBandwidth>=1048576Kbps]
    02-20 21:24:38.731  2072  2720 D WIFI_UT : evalRequest evalRequest  = NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] n.requested= false
    02-20 21:24:38.731  2072  2720 D WIFI_UT :   done
    02-20 21:24:38.731  2072  2719 D WIFI_P2P: got request NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] with score 0
    02-20 21:24:38.731  2072  2719 D WIFI_P2P:   my score=60, my filter=[ Transports: WIFI Capabilities: WIFI_P2P&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=1048576Kbps LinkDnBandwidth>=1048576Kbps]
    02-20 21:24:38.731  2072  2720 D WIFI    : got request NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] with score 0
    02-20 21:24:38.731  2072  2719 D WIFI_P2P: evalRequest evalRequest  = NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] n.requested= false
    02-20 21:24:38.731  2072  2720 D WIFI    :   my score=60, my filter=[ Transports: WIFI Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=1048576Kbps LinkDnBandwidth>=1048576Kbps]
    02-20 21:24:38.731  2072  2719 D WIFI_P2P:   done
    02-20 21:24:38.731  2072  2720 D WIFI    : evalRequest evalRequest  = NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] n.requested= false
    02-20 21:24:38.731  2072  2720 D WIFI    :   done
    02-20 21:24:38.731  2072  2744 D Ethernet: got request NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] with score 0
    02-20 21:24:38.731  2072  2744 D Ethernet:   my score=-1, my filter=[ Transports: ETHERNET Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
    02-20 21:24:38.731  2072  2744 D Ethernet: evalRequest evalRequest  = NetworkRequest [ id=8, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Specifier: <2>] ] n.requested= false
    02-20 21:24:38.731  2072  2744 D Ethernet:   done
    02-20 21:24:38.751  4377  8371 D Mms/SmsReceiverService: storeMessage()
    02-20 21:24:39.231  2799  3047 D NetworkController.MobileSignalController(1/2): onSignalStrengthsChanged signalStrength=SignalStrength: 31 0 -120 -160 -120 -1 -1 99 2147483647 2147483647 2147483647 -1 2147483647 0x4 gsm|lte level=4
    02-20 21:24:39.231  2799  3047 D NetworkController.MobileSignalController(1/2): getMobileIconGroup(): 0
    02-20 21:24:39.261  2799  3047 D NetworkController.MobileSignalController(0/1): onSignalStrengthsChanged signalStrength=SignalStrength: 28 99 -120 -160 -120 -1 -1 99 2147483647 2147483647 2147483647 -1 2147483647 0x4 gsm|lte level=4
    02-20 21:24:39.261  2799  3047 D NetworkController.MobileSignalController(0/1): getMobileIconGroup(): 15
    02-20 21:24:39.261  3784  3784 D HeadsetPhoneState: Signal level : previous=4 curr=4
    02-20 21:24:39.541  2072  2293 D ActivityManager:  getDeferredInfo final delay 1200
    02-20 21:24:39.721  3784  3784 D HeadsetPhoneState: Signal level : previous=4 curr=4
    02-20 21:24:39.721  2799  3047 D NetworkController.MobileSignalController(0/1): onSignalStrengthsChanged signalStrength=SignalStrength: 28 99 -120 -160 -120 -1 -1 99 2147483647 2147483647 2147483647 -1 2147483647 0x4 gsm|lte level=4
    02-20 21:24:39.721  2799  3047 D NetworkController.MobileSignalController(0/1): getMobileIconGroup(): 15
    02-20 21:24:39.751  3620  6812 V NativeCrypto: Read error: ssl=0xb81ca8d0: I/O error during system call, Connection timed out
    02-20 21:24:39.761  3620  8119 I qtaguid : Untagging socket 88
    02-20 21:24:39.761  3620  6812 V NativeCrypto: SSL shutdown failed: ssl=0xb81ca8d0: I/O error during system call, Broken pipe
    02-20 21:24:39.761  6496  6652 E SPPClientService: [c] [PROV CHANNEL] exceptionCaught : java.net.SocketTimeoutException: failed to connect to velb-pew1gld-1366174266.eu-west-1.elb.amazonaws.com/54.154.79.242 (port 5223) after 15000ms: isConnected failed: ETIMEDOUT (Connection timed out)
    02-20 21:24:39.761  6496  6652 E SPPClientService: [a] Fail connect to server : Fail connect to server.
    02-20 21:24:39.761  6496  6652 E SPPClientService: [g] processError. message.arg1:-616346605,  internalErrorCode:-103
    02-20 21:24:39.771   777  2410 D Netd    : Iface rmnet_data0 link down
    02-20 21:24:39.781  6496  6648 E SPPClientService: [b] SharedConstants.WHAT_INTERNAL_ERROR
    02-20 21:24:39.781  3154  3469 I System.out: (HTTPLog)-Static: isSBSettingEnabled false
    02-20 21:24:39.781  2072  3278 V AlarmManager:  remove PendingIntent] PendingIntent{213f185: PendingIntentRecord{7f28bda com.sec.spp.push broadcastIntent}}
    02-20 21:24:39.781  2072  2723 D ConnectivityService: NetworkAgentInfo [MOBILE (HSPA+) - 501] EVENT_NETWORK_INFO_CHANGED, going from CONNECTED to DISCONNECTED, reason = dataDisabled, [ Transports: CELLULAR Capabilities: MMS&SUPL&DUN&FOTA&IMS&CBS&IA&XCAP&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&BIP LinkUpBandwidth>=11264Kbps LinkDnBandwidth>=43008Kbps Specifier: <1>]
    02-20 21:24:39.781  2072  2723 E ConnectivityService: updateNetworkInfo()
    02-20 21:24:39.781  2072  2723 D ConnectivityService: NetworkAgentInfo [MOBILE (HSPA+) - 501] got DISCONNECTED, was satisfying 5
    02-20 21:24:39.781  3620  8119 I System.out: (HTTPLog)-Static: isSBSettingEnabled false
    02-20 21:24:39.781  2072  2723 V NetworkStats: updateIfacesLocked()
    02-20 21:24:39.781  2072  2723 V NetworkStats: performPollLocked(flags=0x1)
    02-20 21:24:39.781  2072  2723 D NtpTrustedTime: currentTimeMillis() cache hit
    02-20 21:24:39.781  2772  3029 D DcNetworkAgent: NetworkAgent: NetworkAgent channel lost
    02-20 21:24:39.781  2772  3029 D DcNetworkAgent: NetworkAgent: DcNetworkAgent: unwanted found mNetworkAgent=null, which isn't me.  Aborting unwanted
    02-20 21:24:39.781  3620  8119 I qtaguid : Tagging socket 70 with tag 31065fff00000000{822501375,0} for uid -1, pid: 3620, getuid(): 10010
    02-20 21:24:39.791  2072  3331 V AlarmManager:  remove PendingIntent] PendingIntent{d7e280b: PendingIntentRecord{614527 com.google.android.gms broadcastIntent}}
    02-20 21:24:39.791  6496  6648 E SPPClientService: [b] handleError->resultCode: PROVISIONING_FAIL(-103)
    02-20 21:24:39.791  2072  2723 V NetworkStats: performPollLocked() took 10ms
    02-20 21:24:39.791  6496  6648 E SPPClientService: [b] redoProvisioning()
    02-20 21:24:39.791  2072  2723 D ConnectivityService: getAllNetworkState networkCapability  = [ Transports: CELLULAR Capabilities: MMS&SUPL&DUN&FOTA&IMS&CBS&IA&XCAP&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&BIP LinkUpBandwidth>=11264Kbps LinkDnBandwidth>=43008Kbps Specifier: <1>]
    02-20 21:24:39.791  2072  2723 D NtpTrustedTime: currentTimeMillis() cache hit
    02-20 21:24:39.791  2072  2723 D ConnectivityService: getAllNetworkState networkCapability  = [ Transports: WIFI Capabilities: WIFI_P2P&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=1048576Kbps LinkDnBandwidth>=1048576Kbps]
    02-20 21:24:39.801  2072  2718 D NtpTrustedTime: currentTimeMillis() cache hit
    02-21-2017 03:48 AM
  5. fedemelo's Avatar
    Guys, at least I am glad I'm not alone in this world. I've been around this for years now without a solution. In stated with my first update on S6 dual and same thing once I've got my S7 dual. Basically every since they add the shortcut to SIM card manager on the top of screen. And yes, like everyone says, it changes the SEM shown as the selected for data when you roll down the top of the screen, but if you go to SIM card manager if it's still showing the correct one, but the real problem is that when that happens, which is seconds after making your selection, it disconnects from both leaving you without data. I am in Argentina, using a local provider and USA t-mobile. The problem occurs only in one way, I mean, when I pick the SIM from Argentina as the primary, but does not happen when I pick t-mobile as the primary one. Tried so many thinks. My conclusion is that it is a software issue without a doubt, but it only occurs with some carriers and areas. But for sure it is a software issue because my S6 worked perfect months in Dame area and with same carriers until that update that changed the way of managing SIM cards with that shortcut rolling down from top screen.
    I am really tired of it... I am always hoping next update will fix it, but it has not updated in ages.
    06-06-2017 07:24 PM
  6. fedemelo's Avatar
    06-06-2017 07:30 PM
31 12
  1. Lack of touch screen sensitivity along bottom edge
    By GregS2 in forum Samsung Galaxy S7
    Last Post: 02-21-2018, 10:20 PM
  2. How can I fix the Bluetooth on my Galaxy Note 5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 04-29-2016, 09:43 AM
  3. My Galaxy Note 5 when connected to my computer won't show up, why?
    Last Post: 04-28-2016, 08:43 PM
  4. People Edge not on phone?
    By Portnell01 in forum Samsung Galaxy S6 edge
    Last Post: 04-28-2016, 08:03 AM
  5. Why can't I get past the boot screen on my Galaxy S3?
    By ShanoGamer in forum Samsung Galaxy S3
    Last Post: 04-28-2016, 05:47 AM
