1. Antmf's Avatar
    I have AOD on and even though I have content hidden on locked screen send a notification pops up saying contents hidden there is another bigger pop up that display the whole message. Is that the way it works? Or can I fix that?
    04-28-2016 11:32 AM
  2. PJRed2008's Avatar
    AOD is essentially a blank screen with a clock and maybe a calendar depending on whether you have that turned on. It appears you're describing the lock screen which has nothing to do with AOD.
    There are a couple places that contain settings for notifications, it sounds like you haven't set them all to off.
    04-28-2016 11:50 AM
  1. How to restore stock ROM on Coolpad Arise ( 5560S ) without PC?
    Last Post: 09-01-2017, 07:41 PM
  2. How do I hack a wifi password on Android phone without rooting?
    Last Post: 04-28-2016, 04:01 PM
  3. Need to use fastboot boot command with bootloader locked?
    By marco sandri in forum Software Development and Hacking
    Last Post: 04-28-2016, 11:49 AM
  4. "Your Message has been erased/deleted. If you ..." What causes this?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 04-28-2016, 11:27 AM
  5. Hide Reminders in Calendar but receive notifications?
    Last Post: 04-28-2016, 11:25 AM
