1. tjtkahfi's Avatar
    Can anybody tell me what is the differences, besides the size of the image of course (the 4:3 with 16:9)?
    04-28-2016 05:23 PM
  2. Aquila's Avatar
    That's it. They're cropping down the 4:3 into a 16:9, so you get a smaller picture.
    04-28-2016 05:34 PM
  3. tjtkahfi's Avatar
    Is there any other differences? So, the noise, the quality of the photos will be the same? None of it will be superior/inferior?
    04-28-2016 11:46 PM
  4. Alanhd's Avatar
    What you see will be the same, you just see less of it. The main thing to consider is do you print your photos. 16:9 would have to be cropped more for printing standard formats.
    04-29-2016 12:43 AM
  5. tjtkahfi's Avatar
    It is better to use the 12MP then?
    05-02-2016 01:04 PM
  6. Alanhd's Avatar
    In My situation 12mp is best for me, It uses the full resolution of the sensor and if I want to print it its better.
    Some people prefer 16:9 as it shows as a full image on the screen but i don't care about that.
    If your not printing go with what you prefer, 4:3 suits my workflow.
    05-02-2016 01:36 PM
  7. Wizzy's Avatar
    Yes. The use of the full sensor will allow you to crop to 16:9, if desired, and adjust up or down for any composition error when you took the picture. You have nothing to lose other than the time required to crop the photo.
    Posted via the Android Central App from my S7 edge
    05-02-2016 06:16 PM
  1. My device was lost, found, and now looks empty?
    By Logan Defoe in forum General Help and How To
    Last Post: 04-29-2016, 05:12 AM
  2. Replies: 1
    Last Post: 04-28-2016, 06:03 PM
  3. Tasker and Samsung Pay
    By TheotherJohn in forum Android Apps
    Last Post: 04-28-2016, 04:24 PM
  4. gear watch and galaxy 6 don'the connect
    Last Post: 04-28-2016, 04:04 PM
  5. Replies: 0
    Last Post: 04-28-2016, 03:18 PM
