1. SocratesRising's Avatar
    Swipe to answer is annoying to me, does anyone out there know if there is an option to change that to simply press a button?
    04-30-2016 07:21 AM
  2. sydneycooper1979's Avatar
    Not that I know of at least in the stock system. I wonder if you could change it by downloading a third party phone dialer app?
    04-30-2016 08:04 AM
  3. jlo3378's Avatar
    You can set it up to answer by pressing home button and ending the call with the power button. Open phone app, tap more on top right, settings, answering and ending calls.
    04-30-2016 08:20 AM
  4. SocratesRising's Avatar
    Awesome, thanks!
    04-30-2016 08:43 AM
  5. Kirk Burkhead's Avatar
    Not sure why mine is different, but I don't have to swipe to answer. I can just tap the green button on incoming calls to answer, or tap the red decline button to decline.
    04-30-2016 09:22 AM
  6. Dhawk1202's Avatar
    Under accessibility settings, turn on Single Tap mode. That will do the trick for you.
    04-30-2016 10:40 AM
  1. Why doesn't my audio jack work with phone calls?
    Last Post: 08-16-2016, 03:25 AM
  2. Can I get calls during games?
    By Mickey_X in forum Samsung Galaxy S7 edge
    Last Post: 04-30-2016, 09:07 AM
  3. Replies: 0
    Last Post: 04-30-2016, 03:40 AM
  4. Does using the video call feature use data?
    Last Post: 04-29-2016, 03:56 PM
  5. Replies: 0
    Last Post: 04-29-2016, 11:03 AM
