Where are my music downloads?
SIOP
Active member
Oct 2, 2013
40
Downloaded some songs from the App Store that went into Google Play Music. Want to move them into my regular music folder but can't find them anywhere. Anybody know where they might be hiding? Thanks!
Aquila
Retired Moderator
Feb 24, 2012
15,904
Are they songs that you purchased or pinned from the app? If they're purchased, you have to download to a PC and then transfer the mp3. If you haven't purchased them, they're stored as files that can't be read by any other apps, etc and are only available through the Google Play Music app for offline listening.
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
Google makes that folder inaccessible when downloading music from the play store, probably to prevent sharing.
Like others have said, downloading to your computer first and then transferring them to the phone is the only way to access the folder on the phone for other uses.
Laila Nance
