1. Seremedy's Avatar
    Im confused, ive heard people say: do not do a software os update before unchecking all your disabled bloatware. Is it okay to keep all your bloatware disabled on package disabler pro ? Or do you need to uncheck all the bloatware from package disabler, then do the os update ?
    05-02-2016 04:56 PM
  2. dizzll's Avatar
    I left mine the same (87 disabled) and noticed no difference from the update
    05-02-2016 05:29 PM
  3. mitul_mehta's Avatar
    I second that.. it works fine even if things are disabled.
    05-02-2016 08:54 PM
  4. Seremedy's Avatar
    Even for android os updates ? Not talking app update like the app package disabler updates.
    05-02-2016 09:45 PM
  5. meyerweb#CB's Avatar
    I think as long as the apps are still on the phone the OTA won't care if they're "disabled." The code is there and can still be updated. But if you're worried about it, tap on the 3 dot menu and export your settings, then enable everything before you update. Then import the file you exported before.
    05-06-2016 03:55 PM
  6. dpham00's Avatar
    It is recommended that you enable before update but I have done updates without enabling the disabled packages and it works fine
    05-06-2016 05:19 PM
  1. Pixel C, ipad Pro, or Surface Pro 4
    By Byrese in forum Pixel C
    Last Post: 06-18-2016, 07:28 AM
  2. Anyone swapped their S7e with the 10?
    By Cool Jeff in forum HTC 10
    Last Post: 05-19-2016, 10:32 PM
  3. GO SMS PRO 2016 Sound Notification on Galaxy s6 edge +
    By mswinkle in forum Samsung Galaxy S6 edge+
    Last Post: 05-02-2016, 11:04 PM
  4. Replies: 1
    Last Post: 05-02-2016, 02:23 PM
  5. Replies: 0
    Last Post: 05-02-2016, 06:54 AM
