1. DigitalMiha's Avatar
    Hello!
    I forgot my lock screen PIN. I can still access my phone via fingerprint but can't change my fingerprint settings because they require my PIN. How can I solve this?
    Thank you!
    05-04-2016 05:17 AM
  2. aldo82's Avatar
    Factory reset from the recovery menu? That's a difficult one as the pin is always needed and seems to take priority over fingerprint. I'm not sure you can even reboot your phone as you need the pin to access it first time after starting up
    05-04-2016 05:44 AM
  3. chanchan05's Avatar
    Doesn't Android device manager let you retrieve or change PIN remotely? Not sure.
    05-04-2016 06:44 AM
  4. danlnyc's Avatar
    How do you forget your PIN #?
    05-05-2016 06:23 PM
  5. Wizzy's Avatar
    I would do a complete backup and then factory reset. I prefer Samsung's over Google's as I've never had good luck with Google's restore functionality.
    Posted via the Android Central App from my S7 edge
    05-05-2016 06:50 PM
  6. DanieSw's Avatar
    How can you help me
    04-19-2018 10:55 AM
  1. Why does my phone lag when headphones are plugged in?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 05-05-2016, 09:58 AM
  2. Replies: 1
    Last Post: 05-04-2016, 05:17 PM
  3. Why don`t my backspace work after update?
    By AC Question in forum Samsung Galaxy S5 Mini
    Last Post: 05-04-2016, 01:45 PM
  4. Replies: 2
    Last Post: 05-04-2016, 11:04 AM
  5. Why does my sprint Note 4 not have any
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-04-2016, 06:41 AM
