05-08-2016 03:15 PM
33 12
tools
  1. datgoldmember's Avatar
    Woke up this morning to this update on my T-Mobile S7 Edge
    Mod Edit - T-Mobile Galaxy S7 and S7 edge updates fix power and volume button bugs | Android Central
    Attached Thumbnails New T-Mobile S7 Edge Update 5/4/16-8077.jpg
    ironass likes this.
    05-04-2016 05:42 AM
  2. llfloyd79's Avatar
    Yeah received mines as well.
    05-04-2016 05:47 AM
  3. datgoldmember's Avatar
    Do you see where the FM radio option is located? I don't see it as an app or in the system app list
    lsmith9523 likes this.
    05-04-2016 06:36 AM
  4. mzceetee's Avatar
    Exactly what I was looking for, unable to find it..
    05-04-2016 06:42 AM
  5. stevemustang's Avatar
    Just got it
    Attached Thumbnails New T-Mobile S7 Edge Update 5/4/16-724.jpg
    05-04-2016 06:45 AM
  6. stevemustang's Avatar
    I dont see the fm radio but they added a new wallpaper
    05-04-2016 06:49 AM
  7. NexusGirlX's Avatar
    I'm sure someone will figure out where the radio is eventually.
    05-04-2016 06:53 AM
  8. erasat's Avatar
    I think they just activated the FM radio, but now we just need to download any FM radio app. I will try this later and will see what happens.
    NexusGirlX likes this.
    05-04-2016 07:15 AM
  9. cd247's Avatar
    What is the best FM radio app for the Galaxy S7 Edge. Preferably one that uses the least amount of data
    Galaxy S7 Edge: Silver Titanium
    05-04-2016 07:22 AM
  10. Dhawk1202's Avatar
    Preferably one that uses no data.... As in on the binge on program.
    05-04-2016 07:55 AM
  11. cd247's Avatar
    No, as in, can work in airplane mode or without wifi/mobile connection. I work in a dead zone building.
    I have Binge on but doesn't help without a connection....
    05-04-2016 08:04 AM
  12. cd247's Avatar
    No, as in, can work in airplane mode or without wifi/mobile connection. I work in a dead zone building. FM radios work in the building.
    05-04-2016 08:05 AM
  13. robfil's Avatar
    You need to download a radio application such as Nextradio and you need your wired headphones plugged in to work as an antenna.
    05-04-2016 09:03 AM
  14. itsnotmeitsyou's Avatar
    ^ this. And FM radio apps, such as NextRadio, work without a data connection. After all, that's the whole point of the FM transmitter. You can always stream local radio online.
    05-04-2016 09:32 AM
  15. ThrottleJohnny's Avatar
    May security patch. I'm impressed.
    itsnotmeitsyou and SpookDroid like this.
    05-04-2016 09:48 AM
  16. erasat's Avatar
    I downloaded NextRadio free and it works very well with the headphones as your Antenna. I'm still looking for a simpler FM radio app, one that looks just like the OEM ones, just a plain tuner, but I think I'm asking too much, after a while I didn't find anything similar, so I just downloaded Nextradio.
    05-04-2016 10:08 AM
  17. SpookDroid's Avatar
    It includes the May security patch!! Nice T-Mo!!!
    Almeuit likes this.
    05-04-2016 01:21 PM
  18. mgm83's Avatar
    Also added some fixes and stability improvement.. whatever that means..
    05-04-2016 01:23 PM
  19. Almeuit's Avatar
    05-04-2016 01:47 PM
  20. cd247's Avatar
    Thanks. The headphones as an antenna seemed silly. I thought it was bs
    05-04-2016 02:08 PM
  21. SpookDroid's Avatar
    That's always been the case on phones with FM Radio (unless it has a dedicated antenna). It needs something to act as an antenna, and the headphones cable is the perfect substitute on a phone.
    05-04-2016 02:50 PM
  22. mgm83's Avatar
    Is there any way around it? Just wondering if it would work without the headphones
    05-04-2016 04:12 PM
  23. SpookDroid's Avatar
    You could re-code the app (not sure if the 'wire' check is in the OS or the radio app, though) and make it skip it asking for the headphones, but just like an FM radio with no antenna, chances are that if you do use it like that you'll only get static.
    05-04-2016 04:17 PM
  24. datgoldmember's Avatar
    I've been using TuneIn Radio Pro on this phone from day one on my early delivered pre-order,which is FM radio..I was under the impression there would be an actual samsung radio app maybe..but either way great job T-Mobile on the update and the May security.
    05-04-2016 04:24 PM
  25. Trees's Avatar
    Nice, cool to see FM radio availability. Hope the trend continues with Note 6
    05-05-2016 06:37 AM
33 12
  1. Note 5 gallery stopped working after MM 6.0 update
    By mhtsang in forum Samsung Galaxy Note 5
    Last Post: 05-31-2016, 02:40 PM
  2. Galaxy S6 Android update
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-08-2016, 08:18 AM
  3. Screen sensitivity in galaxy s7
    By AC Question in forum Samsung Galaxy S7
    Last Post: 05-04-2016, 06:20 PM
  4. Samsung Galaxy S7 Edge vs iPhone 6S Plus Drop Test! (Video)
    By monicakm in forum Samsung Galaxy S7
    Last Post: 05-04-2016, 04:06 AM
  5. Replies: 0
    Last Post: 05-03-2016, 09:21 PM
