two Wi-Fi access points with same SSID cause reconnections
I have a specific Wi-Fi problem with two access points using same SSID. My Samsung Galaxy S7 Edge keeps reconnecting to the network every several minutes. It started happening with my previous Galaxy S6 Edge, and it did not happen with my previous phones. I don't have such problem at home or any other place, only at the office.
I suspect it has to do with the two access points. Our system administrator has the same suspicion but is unwilling yet to fiddle with frequencies, instead he told me that my desk is located right between the access points and I should find a way to ignore one of the access points.
I tried to look for an app that would do it, but to no avail.
I have the Smart Switch turned off, Wi-Fi and Bluetooth scanning in "Location" - "Improve accuracy" are also turned off.
The whole problem is frustrating because I can't enjoy streaming music, every reconnection stops the streaming.
Does anybody have a solution? How should Wi-Fi frequencies by modified in order to solve my problem?
