05-10-2016 08:18 AM
41 12
tools
  1. anon(238680)'s Avatar
    See on another news feed that Verizon has approved an update for the S7/S7e that we should be seeing soon. Nothing on my phone yet, still says it's up to date.
    05-06-2016 11:51 AM
  2. metz65's Avatar
    Mine is updating now.
    mitul_mehta likes this.
    05-06-2016 12:13 PM
  3. anon(238680)'s Avatar
    Yea, mine just downloaded also. Didn't take very long to download so doesn't seem to be that large.
    05-06-2016 12:21 PM
  4. marlin29311's Avatar
    Just updated, brings phone to May 1 security patch.
    05-06-2016 12:59 PM
  5. felloffthetruck's Avatar
    Installing it now.
    05-06-2016 01:00 PM
  6. jmunchies1's Avatar
    Does anyone know if FM Radio was enabled like on the T-Mobile variant? I'm guessing no cause VZW always disables it
    05-06-2016 01:21 PM
  7. felloffthetruck's Avatar
    Were can U find it?
    05-06-2016 01:33 PM
  8. bsteppuhn's Avatar
    I did notice qhen i went back into the disabler i seen a new thing but its not the fm
    05-06-2016 01:54 PM
  9. felloffthetruck's Avatar
    This update states that it fixes the SD card notification pop ups. I did have the pop up upon reboot but I believe that's normal. Keeping fingers crossed this may finally be fixed.
    05-06-2016 02:45 PM
  10. dunamis's Avatar
    since the update...now it won't allow me to unlock with fingerprint when locking with double tap (Grenify & hibernate)? anyone else?
    05-06-2016 03:10 PM
  11. jazz70's Avatar
    I didn't see anything in the update notes specifically mentioning anything about the "touch screen sensitivity update" that was released a month or so ago from Samsung for the s7e so I guess that update is still working its way through VZ's approval process
    05-06-2016 05:18 PM
  12. Bob4seven's Avatar
    I got it earlier. Anybody know what's in it?
    05-06-2016 06:19 PM
  13. Almeuit's Avatar
    Verizon's Galaxy S7 and S7 edge update makes it easier to tell if your SIM tray isn't closed and more | Android Central .
    05-06-2016 06:51 PM
  14. travaz's Avatar
    ANd I was so worried that my sim tray was open!
    HA HA joking Downloading for me now
    05-06-2016 10:32 PM
  15. mlblack16's Avatar
    Same here. Before update, I could use screen off and lock app to lock screen with one tap and then unlock with fingerprint right after. Now I have to enter password unless I use lower key.
    I know that's how Android is set up when using fingerprint scanner, but it sucks.
    1812dave likes this.
    05-06-2016 10:56 PM
  16. clintw22's Avatar
    My android system is lower than my screen now on my battery stats. But after the update, it said the update failed but everything went through. Haha. Any ideas why?
    05-06-2016 11:55 PM
  17. metz65's Avatar
    It also installed DT ignite which Verizon failed to include in the change log.
    anon(238680) likes this.
    05-07-2016 02:14 AM
  18. Rumblee1's Avatar
    Absolutely correct, it did install DT ignite. However I read on one of the Android news sites about this happening so I immediately disabled it. Everyone should.
    KPMcClave and Tatt2014 like this.
    05-07-2016 08:25 AM
  19. PsychDoc's Avatar
    What is "DT ignite" and why do you believe it should be disabled?
    05-07-2016 08:30 AM
  20. Almeuit's Avatar
    If I recall correctly.. DT Ignite allows carriers to install post-sale bloatware without your permission.
    05-07-2016 09:40 AM
  21. LdotAdot13's Avatar
    That's exactly what it does. Very to to disable. Just go to settings applications and disable it.
    Sent from Sir Cletus Sexy IV.
    (S7 Edge Titanium)
    Tatt2014 likes this.
    05-07-2016 09:55 AM
  22. Soulfly79's Avatar
    I have the same question.
    I got the update but I'm not sure that fix is in place.
    I guess I'll have to use a while to tell?!
    05-07-2016 09:58 AM
  23. CMYMUD's Avatar
    Hope it fixed the Bluetooth issue
    05-07-2016 10:13 AM
  24. 1812dave's Avatar
    Same issue here using Screen Off & Lock by Katecca. I now have to use Pattern Unlock instead of FP. I use Screen Off & Lock because I don't like locking the phone with the power button, as I often use it to turn off the screen. Since the update caused this issue today, I tried another app for locking the phone from an icon and got the same result. It seems that the update has "increased" security, same as the OS never let us unlock our phone with FP, after a reboot. I wish they would give US options!
    mlblack16 likes this.
    05-07-2016 01:43 PM
  25. oks10's Avatar
    No kidding? I was wondering what it was when my Verizon protection deal scanned it... aaaaand disabled. Lol.
    05-07-2016 01:53 PM
41 12
  1. Where do you find master sync on a Samsung Galaxy S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-12-2016, 02:54 PM
  2. Galaxy S7 Active leaked
    By LonestarROB in forum Rumored Devices Lounge
    Last Post: 05-23-2016, 04:26 PM
  3. T-Mobile S7 Edge and Notification Sounds
    By SpookDroid in forum Samsung Galaxy S7 edge
    Last Post: 05-09-2016, 01:03 PM
  4. Replies: 2
    Last Post: 05-07-2016, 09:50 AM
  5. Replies: 0
    Last Post: 05-06-2016, 11:39 AM
