1. AC Question's Avatar
    All of a sudden when i take a picture in selfie mode in the little preview window the look fine and when I open it it is all black and the faces have a redish tone to them. What is that? It only does in in selfie mode.
    Thanks
    05-07-2016 12:05 PM
  2. Hasebaer's Avatar
    I'm having the same issues. I reset all camera settings, but that didn't help. When I see the preview in the lower right, it's fine. But the moment I'm pulling up the actual image, it's all black.
    06-08-2016 02:26 PM
  3. Golfdriver97's Avatar
    Mod note: moved to S7 Edge forum.
    06-08-2016 04:28 PM
  4. Gator352's Avatar
    Thanks
    Are you sending pics to internal or sd card? If internal, it might be a bad phone. If sd card, the card could be going bad and try sending them to internal.
    06-09-2016 05:06 AM
  5. Freckles48's Avatar
    I am having the same issue with black picture and redish tones. I have a sd card but all my pictures go to it, only selfie images show the issue.
    06-20-2016 11:25 PM
  6. macrotalk's Avatar
    I had the same issue 2 days ago, I fixed it by restarting the phone. But it happen only with Selfies and not normal shots, so I dont think this is a SD card issue. Sounds like we found a bug.
    07-07-2016 07:02 PM
  7. Jimmy Alonso's Avatar
    Restarted my phone, and it fixed it
    08-13-2016 01:40 AM
  8. purnell_Brenda's Avatar
    Thanks
    01-29-2017 06:19 AM
  1. Samsung Galaxy touchscreen sometimes bails out on me?
    By Fillychi in forum Samsung Galaxy S6 active
    Last Post: 05-08-2016, 12:52 AM
  2. Replies: 2
    Last Post: 05-07-2016, 05:27 PM
  3. Some dim LEDs on my phone screen
    Last Post: 05-07-2016, 04:21 PM
  4. Some dim LEDs on my phone screen
    Last Post: 05-07-2016, 11:52 AM
  5. how do l delete pictures from picasa on samsung s5?
    Last Post: 05-07-2016, 11:34 AM
