06-05-2016 12:10 AM
31 12
tools
  1. daravang's Avatar
    A couple days ago my phone prompted me that there was a Samsung software update so I proceeded with it. After my phone finished updating and rebooting, I can no longer unlock my phone using my fingerprint any more. Every time I use my fingerprint from the lock screen, it will prompt me to enter my pin also, every time. Before the update, it only prompted me for a pin# after rebooting. Now it wants me to enter my pin every time, even though I've already gone into the settings and set it to unlock using fingerprint. Does anyone have this problem or know how to resolve it?
    05-09-2016 06:51 AM
  2. teeitupmo#WN's Avatar
    Just delete the old finger print and setup again. Pretty simple to do.
    05-09-2016 07:31 AM
  3. daravang's Avatar
    I did that already but it doesn't work.
    05-09-2016 08:01 AM
  4. themonk's Avatar
    Having the same issue. After the update the phone asks for pin about half the time. Very frustrating!!!!!
    05-09-2016 09:16 AM
  5. erasat's Avatar
    With latest updates if you are using any other method to lock your phone other than the Display Time out or the Power button, like for example the lock Now app or Nova actions, the phone will ask you for the password all the time, it is like if those processes now activates or reset something like it does when you reboot.
    So, are you using something like I mentioned above or are you having the problem with normal lock processes? if you are locking via the power button then try clearing all your Apps cache on the Settings-Storage menu and then do a wipe cache partition on the recovery menu, power off, then press, Home, Volume Up and Power button until you see the Android robot.
    05-09-2016 09:53 AM
  6. themonk's Avatar
    Appreciate the response. Not using any other method to lock other than Display Time out or the Power button. Followed your advice about cleaning the app and phone cache. Still having the issue. I called verizon earlier this morning and all she could do was note the complaint and she said they have been getting a ton of calls about this issue and people are pissed.
    05-09-2016 10:17 AM
  7. erasat's Avatar
    It will always ask you for the password after a reboot, so after you cleared apps cache and wiped cache partition on recovery mode it will ask you for the password, but have you tried after that? I think you should have but just want to be sure. But now that you mentioned Verizon, I think I have read from other Verizon users with the same issues here and in other forums, it may be a Verizon thing.
    05-09-2016 10:35 AM
  8. themonk's Avatar
    Yes on the password at reboot and after. Well seasoned android user here .
    Yea, Verizon pushed out an update this week that messed the fingerprint reader up. Only works about half the time on unlock, otherwise you need to do pin or pattern. So stupid! Don't see the point in fingerprint reader if you cant unlock the phone with it.
    05-09-2016 10:43 AM
  9. PJRed2008's Avatar
    A (potential) firmware issue does not negate the usefulness of the fp reader hardware. The only thing that is 100% in life is death. My fp reader works fine after the update so 'everybody' isn't having the problem.
    05-09-2016 11:31 AM
  10. themonk's Avatar
    FIngerprint reader works fine and this issue is not a hardware issue.
    You are on Verizon?
    You installed the May update?
    Your phone is not prompting you for a pin, password, or pattern half the time now when unlocking your phone?
    05-09-2016 11:35 AM
  11. PJRed2008's Avatar
    You are on Verizon?
    You totally missed my point.
    Yes
    Yes
    No.
    That's what I said.
    05-09-2016 11:42 AM
  12. themonk's Avatar
    Yes
    Yes
    No.
    That's what I said.
    Very cool for you. Too bad you dont have a solution.
    05-09-2016 11:45 AM
  13. PJRed2008's Avatar
    Maybe you could buy a Blackberry...and go bug their forum
    05-09-2016 12:10 PM
  14. yanks4life's Avatar
    Well he is not the only one having the issue, as I am as well and it sucks now as i can't just unlock the phone with fingerprint , have to enter my pattern. I am not using any other apps or anything just power off from power key. I have found the reason it does it only sometimes is if your screen comes on and shuts off on its on it will prompt you the next time. The only way to get the fingerprint to work right is to hit power button and screen can not come on on its on from a notification or anything then u can just use your fingerprint next time. I love how one person says it works fine and he things others can't have the problem. Anyway i wish there was a solution as this sucks!!! I am going to go back to the old way of unlocking with just swiping screen at this rate. Verizon better release a fix ASAP!!!!!!!!!!!!!
    05-09-2016 12:17 PM
  15. themonk's Avatar
    Im good - thanks though!
    05-09-2016 12:17 PM
  16. Thiscrapsucks35's Avatar
    Based on this, I assume you're using Nova Launcher? I had the same issue.
    If you ARE using Nova, you'll have to revoke it's admin permissions on your phone. It means you won't be able to use certain gestures, but it'll resolve the original problem.
    05-09-2016 12:31 PM
  17. themonk's Avatar
    I am using Google Now launcher but went back to twiz and still have the issue.
    05-09-2016 12:36 PM
  18. Thiscrapsucks35's Avatar
    Well I can't explain that one. Sorry themonk.
    It's worth it to check whether GN has admin rights though and disable them if it does.
    05-09-2016 01:23 PM
  19. erasat's Avatar
    OK, so if you hit power it allows the fingerprint next time you unlock but if it's with the Display it doesn't? Then go to Secure lock settings in Lock Screen and Security settings and check and post here your settings. On my T-mobile device I have lock Instantly with power key and then I have it to lock automatically after 5 seconds it turns off.
    I'm curious to know about this as it seems that the key of the issue must be on this menu.
    05-09-2016 01:28 PM
  20. themonk's Avatar
    Thanks Thiscrapsucks!
    So out of frustration I pinged Samsung through their Chat app. They have an app they have you download and they can remote into your phone. He fixed it. Works perfect now.
    I caught about half of what he did and the other part I was in a meeting and just watching when he needed me to to test or enter my pin. Totally sorry I am worthless as I was not able to document the fix. So if you are having the issue hit up samsung support - http://www.samsung.com/us/support/ and scroll down to the bottom of the page and clcik on Live Chat. Whole process took about 20 minutes.
    05-09-2016 01:31 PM
  21. 1812dave's Avatar
    themonk, i can't get your link to work
    05-09-2016 01:43 PM
  22. erasat's Avatar
    I caught about half of what he did and the other part I was in a meeting and just watching when he needed me to to test or enter my pin. Totally sorry I am worthless as I was not able to document the fix. So if you are having the issue hit up samsung support - https://forums.androidcentral.com/e?...token=O_0JNmeR and scroll down to the bottom of the page and clcik on Live Chat. Whole process took about 20 minutes.
    Did you remember going into Lockscreen settings like I mentioned above?
    05-09-2016 01:59 PM
  23. themonk's Avatar
    Fixed - sorry about that. scroll to the bottom of the page and click on live chat
    05-09-2016 02:00 PM
  24. themonk's Avatar
    No, he changed my pattern to a pin and then went into apps > fingerprints and cleared all app data. He then messed with my launcher a bit but I lost him after that. I did not have to rebuild my fingerprints so wiping the app data does not include those.
    05-09-2016 02:03 PM
  25. erasat's Avatar
    Then this just confirmed that is a known bug in the Verizon software, something is getting corrupted during the update process for some users.
    05-09-2016 02:24 PM
31 12
  1. Light weight Antiviurs with Anti-theft protection?
    By joyakhan in forum Android Antivirus
    Last Post: 05-26-2016, 06:44 AM
  2. Replies: 7
    Last Post: 05-12-2016, 03:29 AM
  3. Replies: 1
    Last Post: 05-09-2016, 07:01 AM
  4. Replies: 1
    Last Post: 05-09-2016, 06:12 AM
  5. Need help with screen lock app
    By ditendra in forum Ask a Question
    Last Post: 05-09-2016, 05:46 AM
