1. SPARTONY's Avatar
    Seen this earlier but can't find on the forum... I'm having problems with various text messages that I send get stuck on sending. The fix had something to do with changing something in settings but I couldn't find anything in settings myself. THANKS
    05-09-2016 09:02 AM
  2. N4Newbie's Avatar
    SMS or MMS? (MMS have pictures or other attachments and/or multiple recipients)
    If it is really MMS that you are having trouble with, check to ensure that your APN settings are correct. Settings -> Wireless & networks -> More... (compare to settings recommended by your carrier on their website).
    05-09-2016 09:48 AM
  3. missy8787's Avatar
    R they sending to who u r trying to txt? I was having this issue yesterday on my note 5 it says sending but the person I would txt was still getting the message
    05-09-2016 11:37 AM
  4. N4Newbie's Avatar
    Good point. I used to get that a lot when I was on Sprint, several years ago.
    05-09-2016 11:40 AM
  5. missy8787's Avatar
    I'm on AT&T maybe it's something that will be corrected with an update?
    05-09-2016 11:44 AM
  6. SPARTONY's Avatar
    The only thing I found in Settings was VPN and adding VPN client (??)... I did Google Verizon APN settings and found their recommendations... Still not sure what to do ... And have had co workers with same problem with their Verizon S6 and S7 phones
    05-10-2016 10:01 AM
  1. Replies: 15
    Last Post: 07-10-2018, 08:54 PM
  2. Can't retrieve my text messages.
    By sniemeyer53 in forum General Help and How To
    Last Post: 05-09-2016, 09:50 AM
  3. how do I reset my pin on my Samsung Galaxy 2
    Last Post: 05-09-2016, 08:10 AM
  4. Replies: 0
    Last Post: 05-09-2016, 07:45 AM
  5. Replies: 0
    Last Post: 05-09-2016, 07:42 AM
