1. popkurn611's Avatar
    So I have this setting active under wifi > advanced > keep wifi on during sleep > never.
    Usually when I wake the phone I get a toast notification showing it connects to my network, but recently it is not disconnecting from wifi when the phone is sleeping. When I turn my lockscreen on its already connected to wifi when it should be on 4G.
    05-09-2016 09:37 PM
  2. B. Diddy's Avatar
    Go to Settings>Location, tap Menu>Scanning, and see if it's set to scan with wi-fi.
    05-12-2016 12:34 AM
  3. popkurn611's Avatar
    I have all scanning off, so it's not on set to scan with wifi
    05-12-2016 05:02 PM
  4. B. Diddy's Avatar
    Are there any carrier bloatware apps that might have control over wi-fi? There are some apps that "help" you always look for open wi-fi networks to connect to, and in order to do so, they may have control over turning wi-fi on.
    05-12-2016 06:51 PM
  5. popkurn611's Avatar
    I wish I knew if there was, but can't tell. It worked perfectly on my s6 so not sure why I can't get it to sleep
    05-13-2016 09:03 PM
  6. B. Diddy's Avatar
    I'm talking about any apps that have your carrier name in the title or on the icon. Or any app that claims to be an "optimizer" of sorts.
    05-15-2016 12:32 AM
  7. baazouzia's Avatar
    I have the same issue here after update to marshmallow on s6
    05-16-2016 05:30 PM
  1. My new Eaget V90 will not work on my Samsung S3
    Last Post: 05-09-2016, 09:00 PM
  2. Replies: 0
    Last Post: 05-09-2016, 08:32 PM
  3. SMS Freezing/Not Responding For One Contact
    By gbsteve in forum Samsung Galaxy Note 4
    Last Post: 05-09-2016, 07:40 PM
  4. Why Is My Phone Not Charging?
    Last Post: 05-09-2016, 07:01 PM
  5. Replies: 0
    Last Post: 05-09-2016, 06:11 PM
