1. Rheller82's Avatar
    So while I was playing a game the s7 edge screen distorted and was green on the right side then it just shut off. The button lights still turn on and sound works. Luckily AT&T is sending me a replacement. Anyone else have this happen? Any chance I'll be able to at least temporarily get it working to get my data or if not erase it?
    05-10-2016 04:05 AM
  2. H3aTeRzz's Avatar
    Hi,
    You can try powering if off, if possible....then try entering recovery, wipe cache partition (no data loss). And see if a reboot from there works. Doubtful, but worth a try.
    Chris
    05-10-2016 07:52 AM
  3. Rheller82's Avatar
    Well the screen works a little in recovery, but unfortunately yeah no where else. Even after wiping the cache. Thanks for the idea though.
    05-10-2016 01:36 PM
  1. Nexus 7 (2013) Appears Dead But Has Slow Blinking LED? How Do I Resurrect It?
    By AC Question in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-15-2016, 06:34 PM
  2. Replies: 1
    Last Post: 05-12-2016, 01:30 AM
  3. slide screen will not unlock
    Last Post: 05-10-2016, 04:02 AM
  4. Replies: 0
    Last Post: 05-10-2016, 01:59 AM
  5. Replies: 0
    Last Post: 05-10-2016, 12:51 AM
