1. Skwirl23's Avatar
    Just got the S7 Edge, there is no voicemail ICON in my phone menu or settings. I press Phone Icon on the homescreen, and at the bottom is only gives me Video Call, Green Call Button and Hide at the bottom. Per everything I've seen online, the Voicemail Icon is supposed to be next to the Video Call Icon.
    My voicemail is working, and I get notifications when I receive one. Visual Voicemail is something I got used to using the S6 Edge Plus.
    Please advise
    05-10-2016 01:19 PM
  2. N4Newbie's Avatar
    Who is your carrier?
    Search the play store for "visual voicemail [your carrier name]"
    Laura Knotek likes this.
    05-10-2016 01:43 PM
  3. Bag of Leaves's Avatar
    Have you looked for the app for voicemail in the App Drawer (it may be in a folder in there with your carrier's name as the folder name)? My Sprint phone came with it loaded. In the phone dialer, the link to the voicemail app is to the left of the green call button (there's no video call button). I don't subscribe to visual voicemail because I don't need it or get enough voicemail to justify the few bucks it costs, but the app supports it for those who do (same app as the one on my S3).
    05-11-2016 02:51 AM
  4. Skwirl23's Avatar
    Carrier is AT and T. I searched the Play store and did find AT and T Visual Voicemail. Thanks for the quick response. It's possible that came pre downloaded on my S6 Edge Plus, as I have noticed I don't have as much AT and T apps downloaded on my S7
    05-11-2016 07:23 AM
  5. N4Newbie's Avatar
    Maybe this one? https://play.google.com/store/apps/d....um.androidvmv
    05-11-2016 07:32 AM
  6. Iva_LadyDiCaprio98's Avatar
    I have AT&T and I have voice-mail automatically installed it was there since I got the phone. Are you sure you haven't checked in the app drawer? It's called Visual Voicemail
    05-11-2016 07:36 AM
  7. Skwirl23's Avatar
    It didn't come on my phone, I downloaded the app from the store. I'd like it to be integrated with my phone icon but I can deal with it not.
    N4Newbie, the one you referenced is only for U Verse or Unified Messaging Customers...
    05-13-2016 07:40 AM
  8. lilthrift's Avatar
    I had the same issue when I moved from the iPhone 6s to the s7 edge. I had to call AT&T and have it appended to my new phone and it worked as it was supposed to after that.
    05-13-2016 09:44 PM
  1. Replies: 2
    Last Post: 02-01-2017, 03:44 PM
  2. Replies: 1
    Last Post: 05-12-2016, 03:02 AM
  3. Marshmallow Auto-Arranging Homescreen Icons
    By xsylus in forum Sony Xperia Z3
    Last Post: 05-10-2016, 11:53 AM
  4. Replies: 0
    Last Post: 05-10-2016, 06:59 AM
