Noticed this the other day. If you have animations set to off and press the down arrow in the notification panel, then press it to go back up, the shortcuts go blank. Seems to be an issue with other apps when you want to disable animations as ive just discovered this is the reason the big things up button on FB messenger didn't work for me.
