1. dyna mike's Avatar
    I cleaned house the other day with app permissions on my galaxy s7. Shut the permissions off on apps that I saw no need for permissions in. Ie, some apps wanted access to contacts for no logical reason. It seems I shut off something that controls the recent apps button, because now when I press the button I am told there are no recently used apps. Does anybody know what application is responsible for the recent apps button?
    05-11-2016 12:38 PM
  2. B. Diddy's Avatar
    That's strange. Have you tried starting from scratch and going to the App Manager, tapping Menu, and tapping Reset All App Preferences?
    05-11-2016 09:10 PM
  3. Jay Graham's Avatar
    I am having the same problem. Resetting all preferences did not fix the problem
    05-19-2016 10:52 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Ok, try wiping the cache partition: https://support.t-mobile.com/docs/DOC-24999
    05-20-2016 03:34 PM
  5. bmzero's Avatar
    Same problem for me. I have done a factory reset and cleared cache partition with no success. I have also disabled almost all apps.
    05-22-2016 04:24 PM
  1. Replies: 1
    Last Post: 05-18-2016, 05:07 AM
  2. Messaage app disappeared
    Last Post: 05-17-2016, 03:48 AM
  3. Why my whatsApp not working norma.
  4. Video Call Button in Contact
    By Dan Kunce in forum Samsung Galaxy Note 5
    Last Post: 05-11-2016, 02:28 PM
