1. jaleelhamidd's Avatar
    Does this really save battery life? Will my notifications still come through?
    05-11-2016 05:22 PM
  2. Rukbat's Avatar
    If an app doesn't use the network (or wifi), it saves battery (especially if you have a weak network signal). Will it save a significant amount? When you've used the phone for a few weeks, so you know how the battery acts, turn it all off and see how it acts. (Also, NEVER drain the battery lower than 40%. Lithium isn't a deep-discharge technology.)
    05-11-2016 05:37 PM
  3. pjwk81's Avatar
    Under 40% is around 3pm on these phones now. Not possible to only use it in a 60% range.
    KPMcClave likes this.
    05-11-2016 06:18 PM
  4. Bag of Leaves's Avatar
    Turn it off for any apps you want notifications from while they're closed, such as e-mail and texting apps. I had issues with not getting my e-mail notifications from the two e-mail apps I use (GMail and Kaiten) until I opened them until I made sure that they were not set to battery optimization in either of the two places for it.
    05-12-2016 12:53 AM
  5. jaleelhamidd's Avatar
    When I turn on battery optimization and go back and then open it up again it's turned off lol
    05-12-2016 06:53 AM
  6. Snapperlicious's Avatar
    Are you making assumptions that phone manufacturers are not already preventing you from discharging to zero? Just because the phone says zero doesn't mean the battery is completely drained. I regularly drain my phone's below 40% and I never noticed any significant degradation of the battery. I generally replace my phone's every 1.5-2 years, but the battery has always lasted that long with good endurance. I don't leave my phones on the charger when they don't need to be charged which I feel has a more significant impact on long term battery life.
    Iva_LadyDiCaprio98 likes this.
    05-14-2016 09:09 AM
  1. Replies: 5
    Last Post: 12-06-2016, 02:49 PM
  2. Quick Charge - Effect on Battery?
    By tardus in forum LG V10
    Last Post: 08-23-2016, 11:42 AM
  3. Really poor battery life!
    By Linzyloo88 in forum Samsung Galaxy S7
    Last Post: 05-14-2016, 01:52 AM
  4. Battery stats normal?
    By GS5TR in forum Samsung Galaxy S7
    Last Post: 05-11-2016, 09:07 PM
  5. See data usage just for 1 particular day?
    By michaeljc70 in forum General Help and How To
    Last Post: 05-11-2016, 06:49 PM
