Question guys is there a way when on nova to click the page you want to view instead of scrolling through each page. I know on touchwiz you can click the page indicator under the apps
With Nova you can create a shortcut to 'jump' to any page. Long press on the screen, tap on widgets, drag Nova Actions to the home screen and select 'jump to page'. If you have many pages you can create a shortcut for each one and put them in a folder using numbers as icons from any icon pack.
