1. konvajw's Avatar
    I'm moving from S5 to S7 Edge. Should I use smart switch or setup my new phone manually with settings/apps. Any pros/cons and experiences folks have had would be appreciated. Thanks!
    Posted via the Android Central App - Verizon S5
    05-12-2016 11:36 AM
  2. mitul_mehta's Avatar
    I don't see any issue in using Smart Switch.
    05-12-2016 11:39 AM
  3. anon(238680)'s Avatar
    +1. Did not have any issues and everything was copied over from my SIII. Might not go as well from non-Samsung phone, don't know, but you should be good to go.
    05-12-2016 12:01 PM
  4. DuCeNuKeM's Avatar
    I used smart switch to move everything to over to my s7 edge. I couldn't get to transfer wireless or via otg cable so I made a backup to my sd then put it into my s7 edge to restore. It worked out great!
    05-12-2016 12:16 PM
  5. anon(9408097)'s Avatar
    I used smart switch as well. Pretty convenient. Got everything back the their places. Just the widgets weren't there. And the apps weren't signed in. Other than that everything went well. Wish they could make it even better.
    05-12-2016 02:08 PM
  6. oks10's Avatar
    I actually opted to NOT use Smart Switch when I upgraded from my S5. My reasoning was that after going 2 years without a factory reset I thought it was a great opportunity to start clean as opposed to loading this new phone with a ton of apps that I might not really even need anymore. I just set it up new and installed apps as I thought I needed them.
    flintlock likes this.
    05-12-2016 03:32 PM
  7. anon(9408097)'s Avatar
    That was a good decision a fresh start is always good!
    05-12-2016 05:01 PM
  8. chanchan05's Avatar
    Smart Switch didn't pose a problem because it only sends the apk for the other phone to install. It didn't appear to copy over the app dats actually.
    05-12-2016 05:08 PM
  9. RifterAD's Avatar
    I used it to transfer from my Droid Turbo 2 to the S7E without issue. It did not copy over any app data (or the apps themselves), but it was nice to have everything else quickly set-up. It also helped that the large files were already on my SD card (music/pictures/videos), so that was just a simple SD card transfer.
    05-12-2016 08:02 PM
  10. Bag of Leaves's Avatar
    I used it to transfer my photos and such, but I don't think I used it for apps, since I used it later. I don't know what put the apps on my phone, but it listed all the apps in my Google account and allowed me to select which ones I wanted to install, then it downloaded and installed them. It was part of the phone setup. I wasn't connected to my S3 at the time (I was charging the S7 Edge via wired charger).
    I didn't transfer my music via the app because I wanted to be sure that wouldn't mess up future use of the iSyncr app as well as add more music and playlists, plus add them directly to my SD card.
    05-13-2016 03:30 AM
  1. Why is my planner in s7 not notifying me of events
    Last Post: 09-06-2016, 09:12 AM
  2. Charging problem after update to Android 6.0
    By Juled in forum Sony Xperia Z3 Compact
    Last Post: 05-12-2016, 03:56 PM
  3. Boost+ good or bad?
    By alfe67 in forum HTC 10
    Last Post: 05-12-2016, 01:12 PM
  4. Replies: 2
    Last Post: 05-12-2016, 11:39 AM
  5. Replies: 1
    Last Post: 05-12-2016, 11:05 AM
