06-06-2016 06:06 PM
83 123 ...
tools
  1. Samuel Kennedy's Avatar
    Hey so the guy told me their was a case I could get called the life proof case that makes phones able to withstand water. I got my phone fixed today with the official back part, and now Is ready to go. When I first got the phone I was using it in water. Will I be able to use it without a waterproof case ? He said the something about the seal had been broken. I know the phone can handle water. I'm asking can it know that someone has fixed it. Samsung didn't fix it. Someone ordered the official part for it and it looks good.
    posted from my galaxy s7edge
    05-12-2016 03:03 PM
  2. dpham00's Avatar
    Lifeproof makes a water resistant case for the S7 but not the s7 edge.
    Without knowing what he did, I can't really say but something about the seal being broken isn't promising.
    I wouldn't advise intentional water usage either, the protection is for accidents.
    As for whether or not someone can tell, most likely they can unless he did an impeccable job both inside and out.
    H3aTeRzz likes this.
    05-12-2016 03:08 PM
  3. Samuel Kennedy's Avatar
    We'll I took my phone underwater a couple weeks ago before I drop it on the ground but then today he fixed it with an official back cover from Samsung feels just like brand new, but I don't want all that bulkiness on my phone so is there a simmer kind of waterproof case I can get for my phone? I looked at Amazon and can't find one other than the one that officially waterproof the one that's in case all around my phone.
    05-12-2016 03:40 PM
  4. dpham00's Avatar
    Not that I know of
    05-12-2016 03:56 PM
  5. Rukbat's Avatar
    Not covered. What's covered is a wet phone, not a phone under water pressure.
    Lifeproof makes cases that are more water-resistant than "water-resistant" phones - but a waterproof phone [or case] would warranty the phone against water damage - and Nextel was the last one to do that. There's no such thing as a waterproof case or phone other than 2 plastic baggies (see the 4th from last paragraph in Oh, no! My Phone got Wet!)].) But forget about waterproof phones and cases - there are no such hings. You can have the S7 in 1 meter of water, but putting it into the water might exceed the pressure rating, so use it as a "I spilled my water on the screen" type of safety net. Swimming with it? Almost certain to exceed its ratings (look up the 7 in IP67).
    05-12-2016 03:57 PM
  6. Samuel Kennedy's Avatar
    I don't know if you are new to this but you can have the phone in five feet of water for 30 min. It has been proven and their are Cases that are waterproof. I think the problem is, you haven't looked out there. So I was asking if the phone being fixed would still be okay in water. The phone is resistant to water and works flawlessly after being in the water. Or h20. It has been proven to me and I am using the phone now typing this message. I have dunked the phone in water many times and it's fine. I don't really think you saw the commercials or the reviews and the water testing videos proving the phone able to live in water. So. I will pass on what you said.
    05-12-2016 05:48 PM
  7. Samuel Kennedy's Avatar
    Okay I'm gonna post a link from amazon because I just looked it up. Thanks though.
    05-12-2016 05:48 PM
  8. Samuel Kennedy's Avatar
    There ya go. Done.....
    Now I'm trying to find a case that's slimmer. Is their anyone that knows of some??
    Attached Thumbnails I got my phones back fixed. will it still be able to handle water ?-3375.jpg
    05-12-2016 05:51 PM
  9. jazz70's Avatar
    After going through this and then paying to get your phone fixed your s7e is going straight back into the water
    wow just wow
    05-12-2016 06:24 PM
  10. felloffthetruck's Avatar
    Just use a Go-Pro if you have to film in the water. The S7 edge is not an underwater camera/phone.
    05-12-2016 06:41 PM
  11. Iva_LadyDiCaprio98's Avatar
    There is no guarantee that the phone is water resistant after having been fixed. If the seal has been compromised so has the water resistance because the seal is what makes the phone water resistant to start with.
    05-12-2016 07:42 PM
  12. Samuel Kennedy's Avatar
    wow just wow
    The phone didn't have water damage. No where did I say that. I said the back cracked when I dropped it.
    05-12-2016 07:42 PM
  13. Samuel Kennedy's Avatar
    Right there Ya go. It can handle water..no after this has been fixed will it again be able to last in water.
    05-12-2016 08:25 PM
  14. felloffthetruck's Avatar
    Soak in in a tub of water and find out.
    I would be worried if it was not repaired directly by Samsung.
    05-12-2016 08:39 PM
  15. Samuel Kennedy's Avatar
    Yea maybe. But. Do you know of a good waterproof case that's slimmer and not so bulky. I mean I found one on amazon that is able to seal the phone out of water of depths of 20 feet.
    05-12-2016 09:02 PM
  16. Samuel Kennedy's Avatar
    I have. And it worked. Not a tub but I have dipped it into water. Taken pics and videos in 2 to 3 feet of water and the phone works perfectly. That's before I got it fixed. I think my best bet is to find a good case for it when I use it in the water. But I am looking for a slimmer case. No so bulky. I found one on amazon that surrounds the phone and keeps it waterproof up to 20 feet.
    05-12-2016 09:04 PM
  17. Samuel Kennedy's Avatar
    05-12-2016 09:10 PM
  18. Alanhd's Avatar
    I have a GoPro and no this case is not the same thing, why risk an expensive phone. Water pressure is not just about depth.
    There are many cheaper alternatives to GoPro for underwater photography. I let the kids use a cheaper Kodak underwater camera I have and they love it.
    Why not use the right tool for the job, the S7E is great alround camera but it's no replacement for my DSLR, or even my bridge camera.
    Asfalloth likes this.
    05-13-2016 02:00 AM
  19. flintlock's Avatar
    For underwater use maybe try a Canon D30 or a used Nikonos film camera for even less, not a $792 phone that's not warranted for water damage.
    05-13-2016 05:54 AM
  20. welshmikie's Avatar
    Ghostek have done a atomic 2 case now for the s7 edge
    05-13-2016 09:39 AM
  21. santims's Avatar
    I am gettin gthe back of one of my phones replaced next week. The guy said it will still be waterproof because the glue makes the seal again.
    05-13-2016 12:38 PM
  22. ShinyTop's Avatar
    Yup, just as "waterproof" as it was before.
    05-13-2016 04:20 PM
  23. danlnyc's Avatar
    I don't understand why anybody would spend $80 on an everything resistant case when there are companies out there that does the same thing for 1/5 of the price. They're ripping you all off IMO. The S7 already has the IP68
    05-13-2016 06:47 PM
  24. Samuel Kennedy's Avatar
    Hey so I just had my phone fixed and they used very poor adhesive. There is a place that can use better adhesive. But I was looking at parts for the phone if maybe this part would be something that I would need.
    The ports are all factory sealed but the sides are not very sealed.
    Is they're a part to gauretee to re evaluate the phone in its 1p68 water resistance? I don't wanna buy a case for it
    I like using my phone in water sometimes. Can someone help point me in the right direction ??
    Just looking for a part. I don't have a Warranty and I don't have insurance.
    05-13-2016 07:36 PM
  25. Samuel Kennedy's Avatar
    I had my phone fixed. But they used poor glue. If this other place puts better adhesive on it will it be able to be put in the water again.?
    05-13-2016 07:37 PM
83 123 ...
  1. Cricket works with my AT&T version
    By spw303 in forum LG Watch Urbane 2nd Edition
    Last Post: 06-01-2016, 09:02 PM
  2. WI-FI Back and forth between 5Ghz & 2.4Ghz
    By tardus in forum LG V10
    Last Post: 05-14-2016, 04:55 AM
  3. Can I view what is draining my battery?
    Last Post: 05-12-2016, 09:25 PM
  4. Replies: 1
    Last Post: 05-12-2016, 05:11 PM
  5. Replies: 2
    Last Post: 05-12-2016, 04:51 PM
