1. awriternot's Avatar
    Is anyone else having trouble with not being able to apply fonts that you DL (even from the Galaxy store)? Every. Single. Font. I've downloaded won't work. I keep getting a message that it's not compatible. It's driving me nuts.
    05-13-2016 06:43 AM
  2. Thegreatone3's Avatar
    I used to use HiFont on my Note 4 and that fails every time now with the S7 Edge. Galaxy Store is working just fine for me, however. Currently rocking Comic Sans Pro with no issues.
    05-13-2016 07:38 AM
  3. awriternot's Avatar
    I still can't get any to work.
    08-17-2016 10:57 PM
  4. Tower72's Avatar
    you wont. Samsung removed the ability it use any other fonts other then the ones you have to purchase from the store
    08-18-2016 10:17 PM
  5. Joshua1276's Avatar
    I downloaded Crillee Italic from Samsung and it works fine for me. Im using the Tmobile version completely stock.
    08-20-2016 07:06 PM
  1. Where to buy LG urbane 2nd edition out right with no plan?
    By chramiji in forum LG Watch Urbane 2nd Edition
    Last Post: 08-29-2016, 07:59 PM
  2. Lenovo A680 with lots of virus
    By Allen0202Rach in forum General Help and How To
    Last Post: 08-26-2016, 12:16 AM
  3. Replies: 2
    Last Post: 05-13-2016, 12:30 PM
  4. how to reset kocaso mx780 with out having to go to settings
    Last Post: 05-13-2016, 04:26 AM
  5. Replies: 1
    Last Post: 05-12-2016, 11:42 PM
