1. recDNA's Avatar
    I have always used Lightflow in the past however it doesn't appear to work well with edge 7. Has anyone found a way to dependably set your own led notifications colors? Like I like yellow for missed call not blue. I use green for Gmail. Etc. I've used the same set of colors since og droid days so when I see that color I think that app. I also do not want to disable the active alerts when screen sides light up. Can those colors be controlled?
    05-13-2016 01:43 PM
  2. x1sspic's Avatar
    I too have used Lightflow since my first droid a few years ago. Unfortunately, I just did not have luck getting it to work consistently even following all of the advice here:
    Phone Help - Samsung S7/S7 edge ~ Reactle
    I have had pretty good luck using Light Manager Pro:
    https://play.google.com/store/apps/d...ro&hl=en&gl=us
    I also like the ability to adjust the time that the LED is lit, and not just the time between blinks (I like 1 second on, 1 second off). What I have noticed, however, is that the mixed colors just don't seem to be as accurate as my galaxy S5 and Note 4.
    05-13-2016 02:07 PM
  3. recDNA's Avatar
    So in lightmanager you can set your own colors. They work correctly and the built in thing that lights the sides of the phone when screenndown and notifications come in still works?
    05-13-2016 02:16 PM
  4. meyerweb#CB's Avatar
    05-13-2016 04:08 PM
  5. azie's Avatar
    Somebody knows an app to stop the LED completely during the night?
    05-13-2016 05:23 PM
  1. Repeat of message notification
    Last Post: 05-13-2016, 12:21 PM
  2. Yahoo mail notifications
    By T79phoenix in forum Android Apps
    Last Post: 05-13-2016, 12:07 PM
  3. Screen won't wake up for notifications
    Last Post: 05-13-2016, 11:44 AM
  4. How do I mark message notifications as read?
    By jbtrumps in forum Samsung Galaxy S7 edge
    Last Post: 05-12-2016, 06:35 PM
  5. Notifications and return Texts
    By Khallgrimson in forum Samsung Gear S2
    Last Post: 05-12-2016, 05:15 PM
